Plus One hub struggling with Sky Q ethernet and BT Whole Home Mesh
fcooke
Hi. Hope you can help
I have had a Plus One hub working with fibre for four years with a BT Whole Home Mesh with no major issues. Turned off the wifi on the hub and all has been ok.
I recently added Sky Q with 2 Q mini boxes. Conflict with the BT and Sky mesh systems seemingly even though channels are wide apart on 2.4 and 5. Sky added some extenders which helped initially but the Sky wifi signal still drops out to the mini boxes, I'm guessing due to mesh conflicts?
Thought I'd use Powerline for Sky and turned the Sky Q wifi off.  No mesh conflicts now, obvs, but every time I use the Devolo Magic 2 Powerline the BT Mesh wifi locks up. Undo the Powerline from the Plus One router and wifi is fine again.   Tried a spare ethernet switch to see if Plus One as a router was having issues and makes no difference.
Any advice appreciated.
2 REPLIES 2
Faizan786
Re: Plus One hub struggling with Sky Q ethernet and BT Whole Home Mesh
Get a bt hub 6, cheap as chips on fleabay.
fcooke
Thanks. Bit wary of buying used routers off the flea due to past experience with a “modified” one.
if FTTC hub would let me run Sky Q through Powerline and keep BT mesh running at same time  I’d be happy giving it a go.
