PPPoE
machare
PPPoE
I have not managed to get my OPNsense router to connect to my Plusnet VDSL service via  an Openreach HG612 using PPPoE.
I have a Zyzel router which can connect via this HG612
Is anyone able to advise on how OPBsense should be configured to make this connection?  Googling I have found that others have also had this porblem.
Alternatively is it possible to have my Plusent service changed to use a different connection method via the HG612 such as DHCP?
4 REPLIES 4
Fixes: 586
Re: PPPoE
See if this helps https://forum.opnsense.org/index.php?topic=17485.0
Fixes: 586
Re: PPPoE
Also you will have to either disable gateway monitoring or change the IP used for monitoring as the PN gateway won't respond to pings , see https://community.plus.net/t5/Broadband/PFSense-Connection-Issues/m-p/1916297
Fixes: 480
Re: PPPoE
Moderators Note
This topic has been moved from Broadband to My Router
machare
Re: PPPoE
I eventually got this to work after reverting to an earlier configuration.
