PPPOE disconnects frequently.
- My Router
- PPPOE disconnects frequently.
16-06-2018 11:04 AM - edited 16-06-2018 11:10 AM
Since moving over to Plusnet from Sly i have noticed that my internet keeps dropping a few time a day. I can see that my router keeps synced to the line but PPPoE (PPP0A) keeps dropping and logging back in.
Im using a Draytek vigor 2860 router and am wondering if i have set it up correctly.
Any help would be greatly appreciated.
Re: PPPOE disconnects frequently.
20-06-2018 9:54 PM
Moderator's note:
Topic moved from 'Fibre Broadband' to 'My Router' for clarity.
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
21-06-2018 9:32 AM
Hi John.
I'm not sure how much help I can be here, but those details look correct and from searching "Draytek Vigor 2860" here, there seems to be a few topics about this.
In one instance, a factory reset looked like it fixed this problem so it may be worth trying that.
Also do you experience the same problems using the router we sent you?
21-06-2018 12:14 PM
According to a historic line test, your circuit is dropping sync, not just PPP connection:
21-06-2018 1:31 PM
That graph is pretty much the same as my email alerts i get from my router.
My router is scheduled to reboot every night around 2am and looks like this causes 2 initialisations.
This has only been happening since ive moved to Plusnet, so i wouldn't thought it would be the router or cabling as .
Is it something worth raising a ticket with Plusnet? im not too bothered atm as its not affecting me that much but i wouldn't want it to get any worse.
21-06-2018 9:04 PM
- My Router
