PPP dropping every 24 hours?
- My Router
- PPP dropping every 24 hours?
13-01-2019 12:17 AM - edited 13-01-2019 12:45 AM
Not sure when this has started happening but it dropped whilst I was watching Netflix and looking back over the logs, it happens around the same time every night.
Doesn't look like the actual line de-syncs just the PPP session is dropped and re-established as the DSL uptime counter shows 38 days.
Any suggestions as to why?
00:12:03, 13 Jan. (4416738.750000) WAN operating mode is VDSL 00:12:03, 13 Jan. (4416738.750000) Last WAN operating mode was VDSL 00:12:01, 13 Jan. (4416736.070000) PPP IPCP Receive Configuration ACK 00:12:01, 13 Jan. (4416736.070000) PPP IPCP Send Configuration ACK 00:12:01, 13 Jan. (4416736.070000) PPP IPCP Receive Configuration Request 00:12:01, 13 Jan. (4416736.060000) PPP IPCP Send Configuration Request 00:12:01, 13 Jan. (4416736.060000) PPP IPCP Receive Configuration NAK 00:12:01, 13 Jan. (4416736.060000) PPP IPCP Send Configuration ACK 00:12:01, 13 Jan. (4416736.060000) PPP IPCP Receive Configuration Request 00:12:00, 13 Jan. (4416735.260000) PPP IPCP Send Configuration Request 00:11:58, 13 Jan. (4416733.010000) PPPoE is up - Down Rate=54995Kbps, Up Rate=9995Kbps; SNR Margin Down=13.8dB, Up=17.7dB 00:11:58, 13 Jan. (4416733.000000) CHAP authentication successful 00:11:58, 13 Jan. (4416732.960000) CHAP Receive Challenge 00:11:58, 13 Jan. (4416732.960000) Starting CHAP authentication with peer 00:11:58, 13 Jan. (4416732.960000) PPP LCP Receive Configuration ACK 00:11:58, 13 Jan. (4416732.960000) PPP LCP Send Configuration Request 00:11:58, 13 Jan. (4416732.950000) PPP LCP Receive Configuration Reject 00:11:58, 13 Jan. (4416732.950000) PPP LCP Send Configuration ACK 00:11:58, 13 Jan. (4416732.950000) PPP LCP Receive Configuration Request 00:11:58, 13 Jan. (4416732.950000) PPP LCP Send Configuration Request 00:11:27, 13 Jan. (4416702.840000) PPP LCP Send Termination Request [PPPoE PADT received] 00:11:27, 13 Jan. (4416702.820000) PPPoE is down after 1439 minutes uptime [Disconnected] 00:11:42, 12 Jan. (4330318.340000) WAN operating mode is VDSL 00:11:42, 12 Jan. (4330318.340000) Last WAN operating mode was VDSL 00:11:39, 12 Jan. (4330315.400000) PPP IPCP Receive Configuration ACK 00:11:39, 12 Jan. (4330315.390000) PPP IPCP Send Configuration Request 00:11:39, 12 Jan. (4330315.390000) PPP IPCP Receive Configuration NAK 00:11:39, 12 Jan. (4330315.380000) PPP IPCP Send Configuration ACK 00:11:39, 12 Jan. (4330315.380000) PPP IPCP Receive Configuration Request 00:11:38, 12 Jan. (4330314.750000) PPP IPCP Send Configuration Request 00:11:35, 12 Jan. (4330312.210000) PPPoE is up - Down Rate=54995Kbps, Up Rate=9995Kbps; SNR Margin Down=13.8dB, Up=17.7dB 00:11:35, 12 Jan. (4330312.190000) CHAP authentication successful 00:11:35, 12 Jan. (4330312.140000) CHAP Receive Challenge 00:11:35, 12 Jan. (4330312.140000) Starting CHAP authentication with peer 00:11:35, 12 Jan. (4330312.130000) PPP LCP Receive Configuration ACK 00:11:35, 12 Jan. (4330312.130000) PPP LCP Send Configuration Request 00:11:35, 12 Jan. (4330312.120000) PPP LCP Receive Configuration Reject 00:11:35, 12 Jan. (4330312.120000) PPP LCP Send Configuration ACK 00:11:35, 12 Jan. (4330312.120000) PPP LCP Receive Configuration Request 00:11:35, 12 Jan. (4330312.120000) PPP LCP Send Configuration Request 00:11:05, 12 Jan. (4330281.990000) PPP LCP Send Termination Request [PPPoE PADT received] 00:11:05, 12 Jan. (4330281.980000) PPPoE is down after 1423 minutes uptime [Disconnected] 00:27:45, 11 Jan. (4244883.390000) WAN operating mode is VDSL 00:27:45, 11 Jan. (4244883.390000) Last WAN operating mode was VDSL 00:27:42, 11 Jan. (4244880.570000) PPP IPCP Receive Configuration ACK 00:27:42, 11 Jan. (4244880.570000) PPP IPCP Send Configuration ACK 00:27:42, 11 Jan. (4244880.570000) PPP IPCP Receive Configuration Request 00:27:42, 11 Jan. (4244880.570000) PPP IPCP Send Configuration Request 00:27:42, 11 Jan. (4244880.560000) PPP IPCP Receive Configuration NAK 00:27:42, 11 Jan. (4244880.560000) PPP IPCP Send Configuration ACK 00:27:42, 11 Jan. (4244880.560000) PPP IPCP Receive Configuration Request 00:27:42, 11 Jan. (4244879.930000) PPP IPCP Send Configuration Request 00:27:39, 11 Jan. (4244877.580000) PPPoE is up - Down Rate=54995Kbps, Up Rate=9995Kbps; SNR Margin Down=13.8dB, Up=17.7dB 00:27:39, 11 Jan. (4244877.570000) CHAP authentication successful 00:27:39, 11 Jan. (4244877.530000) CHAP Receive Challenge 00:27:39, 11 Jan. (4244877.530000) Starting CHAP authentication with peer 00:27:39, 11 Jan. (4244877.520000) PPP LCP Receive Configuration ACK 00:27:39, 11 Jan. (4244877.520000) PPP LCP Send Configuration Request 00:27:39, 11 Jan. (4244877.520000) PPP LCP Receive Configuration Reject 00:27:39, 11 Jan. (4244877.510000) PPP LCP Send Configuration ACK 00:27:39, 11 Jan. (4244877.510000) PPP LCP Receive Configuration Request 00:27:39, 11 Jan. (4244877.510000) PPP LCP Send Configuration Request 00:27:09, 11 Jan. (4244847.410000) PPP LCP Send Termination Request [PPPoE PADT received] 00:27:09, 11 Jan. (4244847.390000) PPPoE is down after 1439 minutes uptime [Disconnected] 00:27:44, 10 Jan. (4158482.500000) WAN operating mode is VDSL 00:27:44, 10 Jan. (4158482.500000) Last WAN operating mode was VDSL 00:27:41, 10 Jan. (4158479.810000) PPP IPCP Receive Configuration ACK 00:27:41, 10 Jan. (4158479.810000) PPP IPCP Send Configuration ACK 00:27:41, 10 Jan. (4158479.800000) PPP IPCP Receive Configuration Request 00:27:41, 10 Jan. (4158479.800000) PPP IPCP Send Configuration Request 00:27:41, 10 Jan. (4158479.800000) PPP IPCP Receive Configuration NAK 00:27:41, 10 Jan. (4158479.800000) PPP IPCP Send Configuration ACK 00:27:41, 10 Jan. (4158479.790000) PPP IPCP Receive Configuration Request 00:27:40, 10 Jan. (4158478.970000) PPP IPCP Send Configuration Request 00:27:38, 10 Jan. (4158476.750000) PPPoE is up - Down Rate=54995Kbps, Up Rate=9995Kbps; SNR Margin Down=13.8dB, Up=17.7dB 00:27:38, 10 Jan. (4158476.730000) CHAP authentication successful 00:27:38, 10 Jan. (4158476.690000) CHAP Receive Challenge 00:27:38, 10 Jan. (4158476.690000) Starting CHAP authentication with peer 00:27:38, 10 Jan. (4158476.690000) PPP LCP Receive Configuration ACK 00:27:38, 10 Jan. (4158476.680000) PPP LCP Send Configuration Request 00:27:38, 10 Jan. (4158476.680000) PPP LCP Receive Configuration Reject 00:27:38, 10 Jan. (4158476.680000) PPP LCP Send Configuration ACK 00:27:38, 10 Jan. (4158476.670000) PPP LCP Receive Configuration Request 00:27:38, 10 Jan. (4158476.670000) PPP LCP Send Configuration Request 00:27:07, 10 Jan. (4158445.390000) PPP LCP Send Termination Request [PPPoE PADT received] 00:27:07, 10 Jan. (4158445.380000) PPPoE is down after 1438 minutes uptime [Disconnected] 00:28:10, 09 Jan. (4072111.130000) WAN operating mode is VDSL 00:28:10, 09 Jan. (4072111.130000) Last WAN operating mode was VDSL 00:28:08, 09 Jan. (4072108.340000) PPP IPCP Receive Configuration ACK 00:28:08, 09 Jan. (4072108.340000) PPP IPCP Send Configuration ACK 00:28:08, 09 Jan. (4072108.330000) PPP IPCP Receive Configuration Request 00:28:08, 09 Jan. (4072108.330000) PPP IPCP Send Configuration Request 00:28:08, 09 Jan. (4072108.330000) PPP IPCP Receive Configuration NAK 00:28:08, 09 Jan. (4072108.330000) PPP IPCP Send Configuration ACK 00:28:08, 09 Jan. (4072108.320000) PPP IPCP Receive Configuration Request 00:28:07, 09 Jan. (4072107.750000) PPP IPCP Send Configuration Request 00:28:05, 09 Jan. (4072105.340000) PPPoE is up - Down Rate=54995Kbps, Up Rate=9995Kbps; SNR Margin Down=13.8dB, Up=17.6dB 00:28:05, 09 Jan. (4072105.330000) CHAP authentication successful 00:28:05, 09 Jan. (4072105.280000) CHAP Receive Challenge 00:28:05, 09 Jan. (4072105.280000) Starting CHAP authentication with peer
Re: PPP dropping every 24 hours?
13-01-2019 12:28 PM - edited 13-01-2019 12:58 PM
Struggling to explain this one, but this is definitely a PPP drop and the time it's happening points towards our hardware management platform.
Your device was tagged as part of an early deployment to a newer firmware version late last year, however strangely your device didn't update until early hours of this morning. I can only imagine the PPP drops have been failed attempts to apply this upgrade.
I've just pushed the latest available version to your router that I'm fairly confident will stop this happening. Keep an eye on it and let me know tomorrow if that's not the case.
Note that your router will have rebooted to apply the update so apologies if you were in the middle of anything.
13-01-2019 12:36 PM
Moderators Note
This topic has been moved from Fibre to My Router
13-01-2019 12:37 PM
15-01-2019 8:40 AM
What's the verdict?
15-01-2019 6:59 PM
Still exactly the same:
00:27:54, 15 Jan. (130012.990000) WAN operating mode is VDSL 00:27:54, 15 Jan. (130012.990000) Last WAN operating mode was VDSL 00:27:52, 15 Jan. (130011.300000) PPP IPCP Receive Configuration ACK 00:27:52, 15 Jan. (130011.300000) PPP IPCP Send Configuration Request 00:27:52, 15 Jan. (130011.290000) PPP IPCP Receive Configuration NAK 00:27:52, 15 Jan. (130011.290000) PPP IPCP Send Configuration ACK 00:27:52, 15 Jan. (130011.290000) PPP IPCP Receive Configuration Request 00:27:52, 15 Jan. (130011.280000) PPP IPCP Send Configuration Request 00:27:51, 15 Jan. (130010.020000) PPPoE is up - Down Rate=54995Kbps, Up Rate=9995Kbps; SNR Margin Down=13.9dB, Up=19.2dB 00:27:51, 15 Jan. (130010.010000) CHAP authentication successful 00:27:51, 15 Jan. (130009.960000) CHAP Receive Challenge 00:27:51, 15 Jan. (130009.960000) Starting CHAP authentication with peer 00:27:51, 15 Jan. (130009.950000) PPP LCP Receive Configuration ACK 00:27:51, 15 Jan. (130009.950000) PPP LCP Send Configuration Request 00:27:51, 15 Jan. (130009.940000) PPP LCP Receive Configuration Reject 00:27:51, 15 Jan. (130009.940000) PPP LCP Send Configuration ACK 00:27:51, 15 Jan. (130009.940000) PPP LCP Receive Configuration Request 00:27:51, 15 Jan. (130009.940000) PPP LCP Send Configuration Request 00:27:19, 15 Jan. (129978.040000) PPP LCP Send Termination Request [PPPoE PADT received] 00:27:19, 15 Jan. (129978.030000) PPPoE is down after 1439 minutes uptime [Disconnected] 00:27:40, 14 Jan. (43600.330000) WAN operating mode is VDSL 00:27:40, 14 Jan. (43600.330000) Last WAN operating mode was VDSL 00:27:38, 14 Jan. (43598.600000) PPP IPCP Receive Configuration ACK 00:27:38, 14 Jan. (43598.590000) PPP IPCP Send Configuration Request 00:27:38, 14 Jan. (43598.580000) PPP IPCP Receive Configuration NAK 00:27:38, 14 Jan. (43598.580000) PPP IPCP Send Configuration ACK 00:27:38, 14 Jan. (43598.580000) PPP IPCP Receive Configuration Request 00:27:38, 14 Jan. (43598.560000) PPP IPCP Send Configuration Request 00:27:37, 14 Jan. (43597.290000) PPPoE is up - Down Rate=54995Kbps, Up Rate=9995Kbps; SNR Margin Down=13.9dB, Up=19.2dB 00:27:37, 14 Jan. (43597.280000) CHAP authentication successful 00:27:36, 14 Jan. (43597.230000) CHAP Receive Challenge 00:27:36, 14 Jan. (43597.230000) Starting CHAP authentication with peer 00:27:36, 14 Jan. (43597.220000) PPP LCP Receive Configuration ACK 00:27:36, 14 Jan. (43597.220000) PPP LCP Send Configuration Request 00:27:36, 14 Jan. (43597.210000) PPP LCP Receive Configuration Reject 00:27:36, 14 Jan. (43597.210000) PPP LCP Send Configuration ACK 00:27:36, 14 Jan. (43597.210000) PPP LCP Receive Configuration Request 00:27:36, 14 Jan. (43597.200000) PPP LCP Send Configuration Request 00:27:05, 14 Jan. (43565.280000) PPP LCP Send Termination Request [PPPoE PADT received] 00:27:05, 14 Jan. (43565.250000) PPPoE is down after 723 minutes uptime [Disconnected]
17-01-2019 10:46 PM
Very odd
Right, I've completely reprovisioned your device at our side. Try a factory reset by inserting something into the pinhole at the back of the device until the status light flashes green.
When things come back up, I'm hoping that will be the end of the problem?
17-01-2019 10:58 PM
Ok used a pin until the light turned green, router came back up and was reset to defaults, I guess we will see what happens at 00:30 tonight.
18-01-2019 8:24 AM
00:27:49, 18 Jan. ( 5797.440000) WAN operating mode is VDSL
00:27:49, 18 Jan. ( 5797.440000) Last WAN operating mode was VDSL
00:27:48, 18 Jan. ( 5796.010000) PPP IPCP Receive Configuration ACK
00:27:48, 18 Jan. ( 5796.010000) PPP IPCP Send Configuration Request
00:27:48, 18 Jan. ( 5796.000000) PPP IPCP Receive Configuration NAK
00:27:48, 18 Jan. ( 5795.990000) PPP IPCP Send Configuration ACK
00:27:48, 18 Jan. ( 5795.990000) PPP IPCP Receive Configuration Request
00:27:48, 18 Jan. ( 5795.980000) PPP IPCP Send Configuration Request
00:27:47, 18 Jan. ( 5794.800000) PPPoE is up - Down Rate=54995Kbps, Up Rate=9995Kbps; SNR Margin Down=13.8dB, Up=19.1dB
00:27:47, 18 Jan. ( 5794.790000) CHAP authentication successful
00:27:47, 18 Jan. ( 5794.750000) CHAP Receive Challenge
00:27:47, 18 Jan. ( 5794.750000) Starting CHAP authentication with peer
00:27:47, 18 Jan. ( 5794.740000) PPP LCP Receive Configuration ACK
00:27:47, 18 Jan. ( 5794.740000) PPP LCP Send Configuration Request
00:27:47, 18 Jan. ( 5794.730000) PPP LCP Receive Configuration Reject
00:27:47, 18 Jan. ( 5794.730000) PPP LCP Send Configuration ACK
00:27:47, 18 Jan. ( 5794.730000) PPP LCP Receive Configuration Request
00:27:47, 18 Jan. ( 5794.730000) PPP LCP Send Configuration Request
00:27:15, 18 Jan. ( 5763.090000) PPP LCP Send Termination Request [PPPoE PADT received]
00:27:15, 18 Jan. ( 5763.070000) PPPoE is down after 93 minutes uptime [Disconnected]
18-01-2019 8:36 AM
Just checked myself
I'm now wondering if the hardware management platform is a red-herring, as I can't see how it's causing these drops. Our RADIUS servers do suggest it's a remote influence that's responsible though.
Can you provide a handful of log entries from before the 00:27:15 event please?
18-01-2019 9:18 AM
I'm at work now, I'll try and get the logs at lunchtime.
on 18-01-2019 1:42 PM - last edited on 18-01-2019 7:12 PM by Mav
04:20:58, 18 Jan. (19786.110000) Wire Lan Port 2 up
04:20:48, 18 Jan. (19775.870000) Wire Lan Port 2 down
04:20:45, 18 Jan. (19772.870000) Wire Lan Port 2 up
03:06:28, 18 Jan. BLOCKED 1 more packets (because of ICMP replay)
03:06:27, 18 Jan. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.6.224.32->35.186.224.53 on ppp3)
01:56:15, 18 Jan. BLOCKED 1 more packets (because of ICMP replay)
01:56:14, 18 Jan. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.6.224.32->31.13.90.2 on ppp3)
00:27:58, 18 Jan. ( 5805.740000) CWMP: session completed successfully
00:27:58, 18 Jan. ( 5805.560000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
00:27:51, 18 Jan. ( 5799.380000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
00:27:51, 18 Jan. ( 5799.370000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
00:27:47, 18 Jan. ( 5794.610000) CWMP: session closed due to error: Could not resolve host
00:27:47, 18 Jan. ( 5794.590000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
00:27:47, 18 Jan. ( 5794.580000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
00:27:16, 18 Jan. ( 5764.200000) CWMP: session closed due to error: Could not resolve host
00:27:16, 18 Jan. ( 5764.180000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
00:27:16, 18 Jan. ( 5764.180000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
00:27:16, 18 Jan. ( 5763.810000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
00:23:59, 18 Jan. ath10: STA d4:63:c6:f3:a4:72 IEEE 802.11: WiFi registration failed
00:18:25, 18 Jan. ( 5232.890000) Host android-dhcp-8-1-0-d4-63-c6-f3-a4-72 (MAC d4:63:c6:f3:a4:72) using IP 192.168.1.68 detected on interface ath00, port -1
00:18:19, 18 Jan. ath00: STA d4:63:c6:f3:a4:72 IEEE 802.11: Client associated
00:18:19, 18 Jan. ath00: STA d4:63:c6:f3:a4:72 IEEE 802.11: Client disassociated
00:17:15, 18 Jan. ( 5162.890000) Host android-dhcp-8-1-0-d4-63-c6-f3-a4-72 (MAC d4:63:c6:f3:a4:72) using IP 192.168.1.68 detected on interface ath10, port -1
00:17:10, 18 Jan. ( 5158.140000) Device disconnected: Hostname: android-dhcp-8-1-0-d4-63-c6-f3-a4-72 IP: 192.168.1.68 MAC: d4:63:c6:f3:a4:72
00:17:08, 18 Jan. ath10: STA d4:63:c6:f3:a4:72 IEEE 802.11: Client associated
00:17:08, 18 Jan. ath00: STA d4:63:c6:f3:a4:72 IEEE 802.11: Client disassociated
23:57:52, 17 Jan. ( 3999.780000) Lease for IP 192.168.1.66 renewed by host android-dhcp-8-1-0-80-58-f8-99-cd-3b (MAC 80:58:f8:99:cd:3b). Lease duration: 1440 min
23:57:52, 17 Jan. ( 3999.780000) Device connected: Hostname: android-dhcp-8-1-0-80-58-f8-99-cd-3b IP: 192.168.1.66 MAC: 80:58:f8:99:cd:3b Lease time: 1440 min. Link rate: 121.5 Mbps
23:57:52, 17 Jan. ( 3999.700000) Lease requested
23:57:48, 17 Jan. ath10: STA 80:58:f8:99:cd:3b IEEE 802.11: Client associated
23:57:42, 17 Jan. ath00: STA 80:58:f8:99:cd:3b IEEE 802.11: Client disassociated
23:57:35, 17 Jan. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 3 192.168.1.66->172.217.23.10 on ppp3)
23:57:15, 17 Jan. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 3 192.168.1.66->216.58.204.78 on ppp3)
23:37:35, 17 Jan. ( 2783.210000) Lease for IP 192.168.1.67 renewed by host android-31dc8b14dfb27cdf (MAC bc:20:a4:7b:d6:e6). Lease duration: 1440 min
23:37:35, 17 Jan. ( 2783.210000) Device connected: Hostname: android-31dc8b14dfb27cdf IP: 192.168.1.67 MAC: bc:20:a4:7b:d6:e6 Lease time: 1440 min. Link rate: 144.0 Mbps
23:37:35, 17 Jan. ( 2783.120000) Lease requested
23:37:30, 17 Jan. ( 2778.270000) Lease for IP 192.168.1.67 renewed by host android-31dc8b14dfb27cdf (MAC bc:20:a4:7b:d6:e6). Lease duration: 1440 min
23:37:30, 17 Jan. ( 2778.200000) Lease requested
23:37:29, 17 Jan. ath10: STA bc:20:a4:7b:d6:e6 IEEE 802.11: Client associated
23:37:29, 17 Jan. ath00: STA bc:20:a4:7b:d6:e6 IEEE 802.11: Client disassociated
23:37:05, 17 Jan. ( 2752.870000) Device disconnected: Hostname: android-31dc8b14dfb27cdf IP: 192.168.1.67 MAC: bc:20:a4:7b:d6:e6
23:37:05, 17 Jan. ( 2752.840000) Host android-31dc8b14dfb27cdf (MAC bc:20:a4:7b:d6:e6) using IP 192.168.1.67 detected on interface ath00, port -1
23:36:55, 17 Jan. ath00: STA bc:20:a4:7b:d6:e6 IEEE 802.11: Client associated
23:32:30, 17 Jan. IN: BLOCK [5] Fragmented packet (IP 185.64.189.115->51.6.224.28 fragment_offset=1480)
23:23:59, 17 Jan. ath10: STA 80:58:f8:99:cd:3b IEEE 802.11: WiFi registration failed
23:14:05, 17 Jan. ( 1372.840000) Device disconnected: Hostname: android-dhcp-8-1-0-80-58-f8-99-cd-3b IP: 192.168.1.66 MAC: 80:58:f8:99:cd:3b
23:13:55, 17 Jan. ( 1362.840000) Host android-dhcp-8-1-0-80-58-f8-99-cd-3b (MAC 80:58:f8:99:cd:3b) using IP 192.168.1.66 detected on interface ath00, port -1
23:13:49, 17 Jan. ath00: STA 80:58:f8:99:cd:3b IEEE 802.11: Client associated
22:57:25, 17 Jan. ( 372.830000) Device disconnected: Hostname: Unknown-d4-f0-27-80-1c-90-2 IP: 192.168.1.64 MAC: d4:f0:27:80:1c:90
22:56:17, 17 Jan. ( 305.280000) Lease for IP 192.168.1.66 renewed by host android-dhcp-8-1-0-80-58-f8-99-cd-3b (MAC 80:58:f8:99:cd:3b). Lease duration: 1440 min
22:56:17, 17 Jan. ( 305.280000) Device connected: Hostname: android-dhcp-8-1-0-80-58-f8-99-cd-3b IP: 192.168.1.66 MAC: 80:58:f8:99:cd:3b Lease time: 1440 min. Link rate: 6.0 Mbps
22:56:17, 17 Jan. ( 305.200000) Lease requested
22:56:13, 17 Jan. ath10: STA 80:58:f8:99:cd:3b IEEE 802.11: Client associated
22:56:10, 17 Jan. ath10: STA 80:58:f8:99:cd:3b IEEE 802.11: Client disassociated
22:55:49, 17 Jan. IN: BLOCK [15] Default policy (TCP [31.13.90.49]:5222->[51.6.224.28]:37228 on ppp3)
22:55:38, 17 Jan. IN: BLOCK [16] Remote administration (TCP [89.248.174.141]:36859->[51.6.224.28]:80 on ppp3)
22:55:37, 17 Jan. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.141]:57810->[54.160.73.122]:2350 on ppp3)
22:55:27, 17 Jan. IN: BLOCK [15] Default policy (UDP [185.220.70.139]:8080->[51.6.224.28]:43145 on ppp3)
22:55:20, 17 Jan. BLOCKED 1 more packets (because of Default policy)
22:55:20, 17 Jan. IN: BLOCK [15] Default policy (TCP [216.58.206.46]:443->[51.6.224.28]:49738 on ppp3)
22:55:18, 17 Jan. IN: BLOCK [15] Default policy (TCP [185.53.88.39]:55094->[51.6.224.28]:1433 on ppp3)
22:55:18, 17 Jan. BLOCKED 2 more packets (because of Default policy)
22:55:17, 17 Jan. ( 245.520000) New GUI session from IP 192.168.1.67
22:55:16, 17 Jan. ( 244.470000) Admin login successful by 192.168.1.67 on HTTP
22:55:16, 17 Jan. IN: BLOCK [15] Default policy (TCP [216.58.208.142]:80->[51.6.224.28]:36424 on ppp3)
22:55:16, 17 Jan. IN: BLOCK [15] Default policy (TCP [185.53.88.44]:44071->[51.6.224.28]:9007 on ppp3)
22:55:12, 17 Jan. IN: BLOCK [15] Default policy (TCP [216.58.204.14]:443->[51.6.224.28]:49836 on ppp3)
22:55:10, 17 Jan. IN: BLOCK [15] Default policy (TCP [216.58.213.74]:443->[51.6.224.28]:37265 on ppp3)
22:55:07, 17 Jan. IN: BLOCK [15] Default policy (UDP [185.220.70.139]:8080->[51.6.224.28]:43145 on ppp3)
22:55:05, 17 Jan. IN: BLOCK [15] Default policy (TCP [78.128.112.54]:56311->[51.6.224.28]:1032 on ppp3)
22:55:01, 17 Jan. IN: BLOCK [15] Default policy (TCP [216.58.206.46]:443->[51.6.224.28]:49752 on ppp3)
22:54:57, 17 Jan. BLOCKED 2 more packets (because of Default policy)
22:54:57, 17 Jan. IN: BLOCK [15] Default policy (TCP [176.119.4.12]:45767->[51.6.224.28]:19762 on ppp3)
22:54:52, 17 Jan. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.141]:57810->[54.160.73.122]:2350 on ppp3)
22:54:52, 17 Jan. BLOCKED 1 more packets (because of Default policy)
22:54:52, 17 Jan. IN: BLOCK [15] Default policy (TCP [216.58.206.46]:443->[51.6.224.28]:49738 on ppp3)
22:54:51, 17 Jan. IN: BLOCK [15] Default policy (TCP [216.58.204.14]:443->[51.6.224.28]:49836 on ppp3)
22:54:49, 17 Jan. BLOCKED 1 more packets (because of Default policy)
22:54:49, 17 Jan. IN: BLOCK [15] Default policy (TCP [216.58.208.142]:80->[51.6.224.28]:36424 on ppp3)
22:54:47, 17 Jan. IN: BLOCK [15] Default policy (TCP [216.58.213.74]:443->[51.6.224.28]:37265 on ppp3)
Moderator's note by Mike (Mav): Post released from Spam Filter.
20-01-2019 4:47 PM
Wondering if this issue could be linked to mine...
https://community.plus.net/t5/My-Router/Hub-one-losing-wifi-connection/td-p/1587602/page/3
This thread says fixed, which it is for the person who started it. I joined in the discussion around a week back as my problem seemed similar.
Maybe someone from Plusnet can investigate further?
20-01-2019 4:49 PM
20-01-2019 5:28 PM
Hmm... that might be the next option for me if things don't improve. I'll be very interested to see if it does fix thing for you @cspiby.
We shouldn't really be having to go down this route though. Plusnet's router should be capable of doing the job it's intended for!
- My Router
