PHO as AP - over wireless?
PatJK
So I've followed the guide to using a spare Plusnet Hub One as an AP (as I want to set up a seperate 2.4Ghz gateway more central to the house than the current line in is situated. I've done this over LAN with an ethernet cable but as I want to move it further I don't have an easy way to hide the ethernet cable for the length of distance I want the AP to be, is it possible to connect it to the main router over wifi or is this just not a possibility?
1 REPLY 1
Fixes: 480
Re: PHO as AP - over wireless?
@PatJK  Welcome to the Plusnet Community Fora.
Sorry, it's not possible. You could connect the two using Powerline devices. However be aware that unless both units are on the same circuit your speed will be limited.
