One PC will not/cannot stay connected to the network
rhjones19
I have a number of my devices connected to our home network, all wirelessly without issue.
But my main PC (windows 10)  will not stay connected.  It gets a connection and loses it after a few seconds.
So far I have tried/don:
- rebooting my machine
- updating my network drivers
- uninstalling and reinstall my network drivers
- spoken with microsoft via online chat, and all they say is get a cable
- I have googled, and tried searching for any fixes recommended in various forums (such as this one)
None of these have worked.  Any ideas suggestions appreciated.  Thanks in advanced
24 REPLIES 24
Fixes: 387
Re: One PC will not/cannot stay connected to the network
@rhjones19 Is this a laptop or desktop? Have you tried the MS suggestion of a cabled connection?
Fixes: 480
Moderator's note:
Thread moved from Full Fibre to My Router
rhjones19
Windows 10 Desktop PC
Fixes: 387
If a desktop, what wireless adapter are you using? Desktops tend to work best with a wired connection. How long has this neen happening, and how long has it been successfully connecting wirelessly, previously?
rhjones19
Wireless USB dongle.  It has always worked with zero issues when I use to live.  But now it can't keep a connection.  I have an amazon fire stick and wireless printer on the same wall as my pc, and neither of them have an issue.
I have a cable coming out of the wall by my desktop - but I am yet to find/establish where the other end of the damn thing comes out
Fixes: 387
The wired connection I suggest you use is between your router (which one are you using?) and the erratic machine.
What is the 'unknown' cable attached to?
@rhjones19
take a look at the USB dongle properties, it may be possible to turn off either 2.4 or 5GHz, I'd suggest turning off 5GHz as 2.4GHz signals  have better range.
EDIT: which Hub are you using?
rhjones19
I'm struggling to find out (only moved here a few weeks ago).   It comes through a hole in the wall.
It is a Hub 2
Fixes: 387
If it isn't connected to your Hub2 in some way, I doubt it is related to your internet connection - can you take a photograph and upload a picture to here?
How far is your desktop away from the Hub? - an Ethernet connection between the two is much better than a wireless one.
rhjones19
I would say it’s about 6 or 7 metres. My stepdad has Been able to track the cable and it has been cut
I will upload photos shortly.
Fixes: 387
OK. I know the Ethernet cable supplied with the Hub is shorter than that, but a 10m Cat5e is cheap enough. I suggest you get one, and connect it between one of the yellow ports on the hub, and the Ethernet connection on your desktop.
lahbrannan1
Fixes: 4
Thank you for your recent post @rhjones19
I am sorry to hear of the issues you are experiencing. Should it continue to be problamatic then please direct message us your account username and we will gladily carry out some techincal diagnostics.
Lee Brannan
Fixes: 387
@lahbrannan1 Thanks for replying, but with respect, I doubt there is anything Plusnet can do to solve this issue - it is a purely local one.
outcast
Aspiring Champion
Fixes: 19
@jab1 wrote:
...I doubt there is anything Plusnet can do to solve this issue
How about releasing a new version of firmware for the Hub Two, that allows different SSID for the 2.4GHz and 5Ghz bands ?
That would reduce the number of WiFi connectivity issues that get asked here over and over and over and over again !
