One Hub drops iPhone WiFi connection
- My Router
- One Hub drops iPhone WiFi connection
15-02-2017 8:00 PM
Has anyone experienced intermittent issues where their iPhone doesn't seem to access the internet whilst connected to WiFi?
The WiFi icon on the phone is ok but it fails to respond. If I turn off the WiFi an use the 4G it works ok and when I switch the Wifi back on it works too.
I've made sure that the 2.4Ghz and 5Ghz are called something different (it seems to happen on the 2.4Ghz band in the house upstairs where the 5Ghz band is too weak).
I've tried fixing the 2.4Ghz channel in case it is the channel auto select shifting causing the drop, but there is no discernible difference.
I'm just wondering whether it is the lack of MiMo that is the source of the problem and it is simply 'waiting its turn'
Has anyone else had the same issues? It's a new One Hub and an iPhone 6 Plus
Re: One Hub drops iPhone WiFi connection
19-02-2017 9:10 PM
19-02-2017 9:41 PM
12-01-2018 6:20 PM - edited 12-01-2018 6:20 PM
same here , my 2 kids got iphone they keep having random wifi drop , where me and my partner using samsung don't have the same , i was looking for info about it
13-01-2018 1:52 PM
What you do is separate the 2.4 and 5GHz channels then select the best for your device see: https://community.plus.net/t5/My-Router/Making-5-GHz-have-separate-SSID-with-the-Hub-One/m-p/1349587....
- My Router
