Old firmware on hub 1?
FIXED- Subscribe to RSS Feed
- My Router
- Old firmware on hub 1?
12-10-2018 11:58 AM
I haven't had a firmware update since Software version 4.7.5.1.83.8.237.2.2 Last updated 12/08/17
Should i have had one?
See lots of the below entries in my log that concerns me as do not know if this is normal
( 1071.950000) CWMP: session closed before all requests were acked 10:52:59, 12 Oct. ( 1071.730000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo 10:52:56, 12 Oct. ( 1069.350000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username 10:52:56, 12 Oct. ( 1069.340000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,4 VALUE CHANGE' 10:37:56, 12 Oct. ( 168.980000) CWMP: session closed before all requests were acked 10:37:56, 12 Oct. ( 168.770000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo 10:37:54, 12 Oct. ( 166.640000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username 10:37:54, 12 Oct. ( 166.630000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,4 VALUE CHANGE' 10:37:23, 12 Oct. ( 136.280000) CWMP: session closed before all requests were acked 10:37:23, 12 Oct. ( 136.050000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo 10:37:15, 12 Oct. ( 128.460000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username 10:37:15, 12 Oct. ( 128.450000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,1 BOOT,4 VALUE CHANGE' 10:36:18, 12 Oct. ( 71.080000) CWMP: session closed due to error: Could not resolve host 10:36:18, 12 Oct. ( 71.060000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username 10:36:18, 12 Oct. ( 71.050000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,1 BOOT,4 VALUE CHANGE' 10:35:48, 12 Oct. ( 40.690000) CWMP: session closed due to error: Could not resolve host 10:35:44, 12 Oct. ( 37.310000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username 10:35:44, 12 Oct. ( 37.300000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,1 BOOT,4 VALUE CHANGE'
Fixed! Go to the fix.
Re: Old firmware on hub 1?
12-10-2018 4:03 PM
14-10-2018 12:40 PM
Instructions followed but no update received yet.
I have these entries in my log :
11:08:26, 14 Oct. | (70927.270000) Wire Lan Port 4 down |
10:47:13, 14 Oct. | IN: BLOCK [16] Remote administration (TCP [58.218.66.104]:47922->[146.198.102.179]:8080 on ppp3) |
10:44:58, 14 Oct. | ath00: STA 10:ae:60:16:d6:49 IEEE 802.11: Client associated |
10:44:58, 14 Oct. | ath00: STA 10:ae:60:16:d6:49 IEEE 802.11: Client disassociated |
10:32:17, 14 Oct. | IN: BLOCK [16] Remote administration (TCP [60.18.229.214]:57953->[146.198.102.179]:22 on ppp3) |
10:31:18, 14 Oct. | IN: BLOCK [16] Remote administration (TCP [58.185.70.86]:37503->[146.198.102.179]:80 on ppp3) |
10:28:56, 14 Oct. | IN: BLOCK [16] Remote administration (TCP [187.102.51.51]:30720->[146.198.102.179]:8080 on ppp3) |
10:20:40, 14 Oct. | IN: BLOCK [16] Remote administration (TCP [71.6.202.198]:50000->[146.198.102.179]:80 on ppp3) |
10:18:55, 14 Oct. | IN: BLOCK [16] Remote administration (TCP [189.28.166.9]:38368->[146.198.102.179]:8080 on ppp3) |
14-10-2018 1:04 PM - edited 31-10-2018 12:31 PM
The device will not update beyond .237.2.2 until it is explicitly targeted for upgrade. The firmware is in the process of being rolled out to everyone, and until that rollout is complete and an activation policy put in place, factory resetting will not speed things up.
14-10-2018 2:03 PM
Thanks Bob, but just to double check - I am on 237.2.2. Are you saying that will not upgrade until the next planned rollout?
31-10-2018 12:33 PM
@ra62668, that's right. There's a rollout mis-flight at the moment. I've just pushed you to the front of the queue so you should find your device is now running a more recent build.
