Odd DNS Issue
cpcnw
Odd DNS Issue
Since getting on FTTC [Yes, I was sloooow changing over] I hadn't taken any notice of DNS settings.
Tonight the Internet went 'off' Huh
After a few resets and tests I discovered that adding Googles DNS manually to my clients got them back on?
So I went into the router and added the same to the DHCP settings.
I then used DNS benchmark and realised that Plusnets published DNS
Primary 212.159.13.49
Secondary 212.159.13.50
where faster than Googles!
The issue seems to have been something to do with the router using the alterntives
Primary: 212.159.6.10
Secondary: 212.159.6.9
Odd that. Anyway, all working now.
1 REPLY 1
Fixes: 1,495
Re: Odd DNS Issue
Moderators Note
Topic is likely to be related to DNS issues see https://community.plus.net/t5/Everything-else/DNS-servers-offline/td-p/1937740/jump-to/first-unread-... so locked
