Number of devices
StonesYard
Number of devices
I have a SageCom 2704N and I am struggling to setup 20 devices on my system and it seems I max out at 12. Is there a restriction on how many devices can be added to the network and if so how can it be resolved?
4 REPLIES 4
Fixes: 1,466
Re: Number of devices
Yes, that router maxes out at 12.
You'd need to get a new router to use more.
StonesYard
Thanks @dvorak , do you know if Plusnet will provide a replacement?
Fixes: 1,466
they tend only to send a new router if you recontract.
You might be better off getting a bt smarthub from an auction site, it will be much better than what PN would send out.
If you look around this forum there are discussions and guides on setting it up.
StonesYard
Thanks, I’ve ordered one from eBay, some fun for the weekend 😁
