Noisy fiber router
- My Router
- Noisy fiber router
Noisy fiber router
04-02-2019 10:38 PM
Re: Noisy fiber router
05-02-2019 2:34 AM
I've no personal experience but there are loads of threads about this and it is "normal." The official advise is to switch off the 5GHz bit.
I would have thought that a better bet would be to relocate it out of ear-shot. The best place, assuming you use wi-fi rather than Ethernet, is as close to the middle of the house as possible so the signal is evenly distributed within. I don't know how your house is laid out but my router is in the hall so even if it were to make a noise it wouldn't bother me there.
05-02-2019 11:23 AM - edited 05-02-2019 11:25 AM
Hello @Mistrp74,
Firstly welcome to the forums, and can advise this is something we are aware of. Although the noise
can sometimes annoying, it doesn’t have an adverse effect on performance of the router.
You can eliminate the noise by disabling the 5ghz frequency on the router by following the steps below;
1. Connect to your Wireless or the router via Ethernet. Open Internet Explorer or your browser of choice, delete the contents of the address bar, and enter 192.168.1.254
2. When you press "Enter" or "Return", you will see a page with information about your connection, click "settings" at the top and it will ask you to sign in with a Password.
3. The password is found on the back of your router labelled "Admin password"
4. You will now see the settings page.
5. Under "Settings" click on "Wireless".
6. Click on the "5GHz" under "Wireless"
7. Click no where it states "Sync with 2.4GHz"
8. Click no where it states "wireless network enabled"
9.Click apply at the bottom of the screen.
It will show a red wireless symbol on the router which is nothing to worry about, as it is confirming the router has made the adjustments requested.
Please get back to us if you have any further queries.
