Noisy Router
fire3
Noisy Router
I’ve just switched to plusnet, all is great apart from the router I have been given makes a grinding noise!
Ive tried to call customer services a number of times but have yet to get through, any ideas on how to fix it or how to get a replacement as it’s driving me nuts!
Fixes: 33
Re: Noisy Router
Hi @fire3,
Welcome to Plusnet and to our community forum. I'm sorry that your router has been making a grinding noise and for any inconvenience that this has caused you. This is a known issue that has unfortunately affected a small proportion of our routers recently.
I've sent you out a new router and it'll be with you within 3-5 working days. Please let  us know if there's anything else that you'd like us to look into.
 Emily D
BiffaDaly
Re: Noisy Router
My router is also making a weird noise which is only noticeable when it's under load from wireless devices.
Is there any chance mine could be replaced?
fire3
Re: Noisy Router
Hi Emily
many thanks for that, do I need to send the old one back to you.
kindest regards
Adam
Fixes: 16
Re: Noisy Router
Hello @fire3,
Thanks for getting back to us, you can return to us at the office by following the outlined instructions in this thread here.
Please get back to us if you need any further assistance.
 SammyM
Fixes: 16
Re: Noisy Router
Hello @BiffaDaly,
Sorry to hear your router is behaving in this manner. I will certainly look into this and get back to you on your other thread here.
 SammyM
markstacey83
Re: Noisy Router
My router is also noisey, can I have a replacement too please?
Fixes: 17
Re: Noisy Router
Hi @markstacey,
The noise the router is making could be caused due to the 5Ghz Wi-Fi frequency being in use, and I've included a guide below on how to disable this feature to see if it helps:
1) To connect to your Hub One, you will need to open a browser and go to 192.168.1.254 If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Advanced Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Wireless' followed by '5 GHz Wireless'.
4a) To split up the frequencies:
What we want to do to begin with is turn 'Sync with 2.4 GHz Wireless' to 'No' and update the SSID to be different. The easiest way would be to add '-5G' to the end so it is identified as its own connection.
4b) To disable the 5Ghz frequency:
On this page you'' need to turn 'Sync with 2.4 GHz Wireless' to 'No' followed by turning 'Wireless network enable' to 'No' also. If worked after pressing 'Apply' a wifi red light should appear on the router and the 2.4Ghz standard wireless channel still showing available on your devices.
Please note that if you disable the 5Ghz frequency, the standard 2.4Ghz frequency will still be in use and Wi-Fi connections should still work as normal. Please let us know if this helps or not and if it hasn't we can look into arranging a replacement be sent out.
 Alex H
fire3
Re: Noisy Router
Well I have had the replacement router for a couple of weeks and this too has developed the noise fault!
Fixes: 17
Re: Noisy Router
Hi @fire3, I'm sorry to hear that's the case. Have you tried disabling the 5Ghz frequency using the guide I posted in my previous post on this thread?
 Alex H
fire3
Re: Noisy Router
Hi, yes I’ve tried disabling the 5GHz and resetting it but it’s still noisy.
Fixes: 210
Re: Noisy Router
Have you disabled the 5ghz after resetting the router?
By default if you reset the router you'll have enabled it again
 Matthew Wheeler
fire3
Re: Noisy Router
Yes I disabled it again after a reset, still makes a noise.
Fixes: 19
Re: Noisy Router
Hi @fire3
I've arranged for a further replacement to be dispatched. Let's hope you fare better with this one!
Best wishes
Dave
 Dave G
