No Internet - trying to connect TP Link C80
aitchvee
Hi. Been trying for hours now to replace our old Plusnet router with an Archer c80.
Please can someone tell me if this is actually possible, as I've noticed that some reviews say you can't use it on Plusnet. If this is the case, please can someone tell me why?
Any help much appreciated!
Tags (1)
18 REPLIES 18
Mustrum
Fixes: 77
Re: No Internet - trying to connect TP Link C80
I beleive that router needs a seperate modem.
aitchvee
Sorry, yes I should've said - were using the same BT modem that we were with the Plusnet router.
Fixes: 418
@aitchvee
From my reading you need to set it up manually. Select PPPoE as the connection type and don't forget to add @plusdsl.net to your user name. See https://www.plus.net/help/broadband/broadband-connection-settings/
aitchvee
Hi, thanks, we've tried that. It just won't change from connected no Internet 😕
Fixes: 418
@aitchvee
If all else fails you can always switch off the wireless on your Plusnet Hub and connect it in Access Point mode to one of the Hub LAN outputs.
aitchvee
Thanks, might try that as all else is failing.
What does that actually mean? Would I not be using the router as a router?
Alex
Fixes: 13
I believe it would mean you're not using two routers, just the PlusNet device is just a modem only and passing the traffic onto your router which is actually doing the routing.
So you're only using one.
Fixes: 418
Actually it's unfortunately the other way around. Tthe Plusnet hub is the router and the Archer becomes a repeater. It means rhat you can't use the advanced Archer featurs like guest network. You will however get much better wifi and extra Ethernet ports.
Mustrum
Fixes: 77
Perhaps if you post a pic of your settings someone could help spot where you are going wrong.
From what I could see on the setup it should work - but equally who says it won't?
aitchvee
See next post for pics!
p.s. I searched the Amazon reviews for 'Plusnet', and every one that mentioned it said 'sent it back' 'don't bother'  'doesn't work with Plusnet', etc.
aitchvee
Here are some settings pics. I've reset the settings from what I've tried so I can start from scratch with your advice Smiley
Let me know if there are other settings you need to see.
Mustrum
Fixes: 77
What do you have in the quick setup and operation mode tabs?
aitchvee
Fixes: 418
@aitchvee
It looks like it's not picking up the Plusnet IP address. What you need is for this to be picked up automatically by the router unless you have a fixed IP Address. it might be worth trying the use Dynamic IP Address option Under PPPoE Secondary connection to see what happens.
