No Internet - trying to connect TP Link C80
- My Router
- No Internet - trying to connect TP Link C80
06-09-2020 2:03 PM
Please can someone tell me if this is actually possible, as I've noticed that some reviews say you can't use it on Plusnet. If this is the case, please can someone tell me why?
Any help much appreciated!
Re: No Internet - trying to connect TP Link C80
06-09-2020 2:13 PM
I beleive that router needs a seperate modem.
06-09-2020 2:27 PM
06-09-2020 2:45 PM
From my reading you need to set it up manually. Select PPPoE as the connection type and don't forget to add @plusdsl.net to your user name. See https://www.plus.net/help/broadband/broadband-connection-settings/
06-09-2020 2:47 PM
06-09-2020 3:02 PM
If all else fails you can always switch off the wireless on your Plusnet Hub and connect it in Access Point mode to one of the Hub LAN outputs.
06-09-2020 4:38 PM
What does that actually mean? Would I not be using the router as a router?
06-09-2020 7:27 PM
So you're only using one.
06-09-2020 10:54 PM
Actually it's unfortunately the other way around. Tthe Plusnet hub is the router and the Archer becomes a repeater. It means rhat you can't use the advanced Archer featurs like guest network. You will however get much better wifi and extra Ethernet ports.
06-09-2020 11:27 PM
Perhaps if you post a pic of your settings someone could help spot where you are going wrong.
From what I could see on the setup it should work - but equally who says it won't?
07-09-2020 10:32 AM - edited 07-09-2020 10:51 AM
See next post for pics!
p.s. I searched the Amazon reviews for 'Plusnet', and every one that mentioned it said 'sent it back' 'don't bother' 'doesn't work with Plusnet', etc.
07-09-2020 10:47 AM - edited 07-09-2020 10:49 AM
Here are some settings pics. I've reset the settings from what I've tried so I can start from scratch with your advice
Let me know if there are other settings you need to see.
07-09-2020 11:28 AM
What do you have in the quick setup and operation mode tabs?
07-09-2020 1:01 PM
07-09-2020 1:59 PM - edited 07-09-2020 2:09 PM
It looks like it's not picking up the Plusnet IP address. What you need is for this to be picked up automatically by the router unless you have a fixed IP Address. it might be worth trying the use Dynamic IP Address option Under PPPoE Secondary connection to see what happens.
- My Router
