No 5g connection
- My Router
- No 5g connection
No 5g connection
01-10-2019 8:08 PM
After 4 calls (that's 3+ hours I won't get back) I am connected again but without access to 5g. The fact that I am connected seemed enough and 'something in the house' was blamed.
Can anybody take this further with any educated guesses.
So far I changed the DNS on the devices to 1.1.1.1 then they talked me through changing the channel number, then they split the 2.4/5g on the router. The phone says autentication error the laptops just say can't connect.
Any help really appreciated.
Re: No 5g connection
01-10-2019 8:32 PM
Moderators Note
This topic has been moved from Fibre to My Router
01-10-2019 8:40 PM
on
02-10-2019
6:25 AM
- last edited on
02-10-2019
7:38 AM
by
I've just rebooted my Hub, and rejoined the networks. My Nokia 3 now finds the network again and is using the 5ghz. Not sure how long this will last though.
Moderators Note: Full quote of preceding post removed as per Forum rules
02-10-2019 6:49 PM - edited 02-10-2019 6:51 PM
If you reboot the router, does the 5GHz come back for a while? We know of an issue affecting the 5GHz channel on the latest firmware build, and I'm looking for somebody that can get the router in a 'broken' state and leave it there for a while so we can grab some diagnostics.
Yes, I noticed earlier in the thread that people had reverted to an earlier Firmware version and this sorted it. If it 'breaks and goes back to 2.4 I'll post you back so you can get whatever you need.
I've just tried a reboot when I came home from work and fingers crossed it's holding so far!
Me too
03-10-2019 10:47 AM
Hey @stewart_borland,
Glad to hear it's starting to work correctly for you.
Give us a shout if you need further support.
Thanks.
03-10-2019 6:05 PM
Fingers crossed - still got 5G!
