New router
- My Router
- New router
New router
11-03-2021 9:46 PM
Why don’t plus net supply latest hard ware routers rather than 5 years old tech
be nice if they supply the new bt hub
Re: New router
11-03-2021 9:50 PM - edited 11-03-2021 10:08 PM
interface Vlan1
no ip address
ip nat inside
ip virtual-reassembly in
interface Vlan10
ip address 192.168.1.254 255.255.255.0
ip nat inside
no shutdown
exit
Re: New router
11-03-2021 9:55 PM
Sorry. The specs of the BT hub 2 is higher than the plus net
Re: New router
11-03-2021 10:24 PM
Plusnet are BT’s budget ISP and provide a budget hub compared with their more expensive master.
However Smarthubs can be picked up for peanuts on auction sites and can be used on your Plusnet service. See the links in this post. https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601
Re: New router
11-03-2021 10:27 PM
Is it worth getting or is a net gear Orbi mesh better
Re: New router
11-03-2021 10:31 PM
Also if plus net but budget isp does that mean the speed and stable service lower
Re: New router
11-03-2021 10:40 PM
Let me put it this way, an Orbi mesh router is, as far as I am aware, just a router. Consequently if you want to use one on FTTC or ADSL you will also need to buy a modem. You can possibly configure it as an Access point to use it with your Plusnet hub but you will lose the use of the Orbi’s advanced features.
You can pick up a Smarthub for about £20 or less on EBay, I believe that an Orbi mesh system will cost more than £200.
An Orbi system will give you better WiFi coverage. The choice is yours.
Re: New router
11-03-2021 10:42 PM
Plusnet use the same Openreach infrastructure as BT.
Re: New router
11-03-2021 10:44 PM
So that mean sane speed same services but different server ?
Re: New router
12-03-2021 7:48 AM
What advance feature would I lose?
ive still got the open reach modem anyway
