New Router
mactell
New Router
Hello,
Are PlusNet bringing out a new router any time soon? The current one is based off the very old version of the BT home hub.
5 REPLIES 5
Fixes: 421
Re: New Router
I very much doubt that you will get an answer to this one. Many of us have bought a BT Smarthub 6 for £20-30 from Ebay and use that. You will find the set up instructions on the Router board.
If you currently have a Hub Zero the performance will be in a different league. However you need to separate the 2.4 and 5 GHz bands, again information is on the router board.
SpendLessTime
Fixes: 86
Re: New Router
@Baldrick1 wrote:
If you currently have a Hob Zero
Now you're really cooking Baldrick! Smiley
Strat
Fixes: 565
Re: New Router
Moderator's note:
Topic moved from Broadband to My Router.
Fixes: 421
Re: New Router
@SpendLessTime
I've gone off the boil now!
RandallFlagg
Fixes: 75
Re: New Router
Hi @mactell
Thanks for getting in touch.
I'm not aware of any plans to release a new router at present. I expect that any announcement of such would be done universally via our marketing team in line with whichever deals are available at the time.
Or should that be 'timer', @Baldrick1? Wink
Best wishes
Dave
