New Router Recommendation
- My Router
- Re: New Router Recommendation
04-08-2020 3:24 PM
I have been using a Plusnet Hub One on fibre for the last 3 years. It's a bit past it now and the legs broke some time ago making it susceptible to falling over lots.
Are Plusnet still using that one as standard? Or can someone recommend another make which is better?
Also - is the Pro Add worth it as there are 3 of us working from home for the foreseeable future now!
Many thanks for any replies.
Philip
Message 1 of 2
(217 Views)
1 REPLY 1
04-08-2020 4:29 PM
Moderators Note
This topic has been moved from Fibre to My Router
Message 2 of 2
(202 Views)
- My Router
