New Router Recommendation
pn0705
I have been using a Plusnet Hub One on fibre for the last 3 years. It's a bit past it now and the legs broke some time ago making it susceptible to falling over lots.
Are Plusnet still using that one as standard? Or can someone recommend another make which is better?
Also - is the Pro Add worth it as there are 3 of us working from home for the foreseeable future now!
Many thanks for any replies.
Philip
1 REPLY 1
Fixes: 1,165
Re: New Router Recommendation
Moderators Note
This topic has been moved from Fibre to My Router
