New Hub 1 - Ethernet speed
- My Router
- New Hub 1 - Ethernet speed
27-10-2017 6:50 PM
I have just installed my new Hub 1 in preparation for move to Fibre in a few days' time.
The 4 ethernet connections are labelled gigabit but in the status section of the router administration page the 2 that are in use are shown as 100Mb
I have two connections to the router - one direct to my PC Gbit Netwrork adapter and the other to my unmanaged Gbit switch and both are showing 100Mb on status.
I have checked and changed ethernet cables which look to have the full 8 connections.
Is the Hub 1 really only 100Mb despite its legend above th eethernet ports?
Re: New Hub 1 - Ethernet speed
29-10-2017 11:56 AM - edited 29-10-2017 12:01 PM
Hi mate,
I have the Hub one and it should display 1000mbs, try a different cat5e and check auto negotiation on your devices network cards are set to auto, or switch it to fixed 1gpbs Full duplex mode and see if that helps.
if your viewing the connection screen in the router page ignore it, it sometimes claims 100, but its not.
I have powerline 1000 and a nas both connected directly all running gbps.
29-10-2017 12:56 PM - edited 29-10-2017 12:59 PM
PS I tried looking at speed options and 1 GB was not available. Also light on unmanaged switch input port had need orange instead of green - which is what alerted me to check router page.
