Network troubles
- My Router
- Network troubles
Network troubles
3 weeks ago - last edited 3 weeks ago
Hi, I'm using a Hub One as my DHCP router (WiFi disabled) along with a separate Wireless AP. All my devices are able to connect to the Internet without issue. My TV is wired directly to the router.
However, when I try to connect to my phone to the TV, it won't connect. The IP address is correct. The event log only shows blocked OUT requests ICMP Replay.
Is there a setting somewhere I can change which will allow my devices to see each other?
Re: Network troubles
3 weeks ago
it could be a double NAT issue.
3 weeks ago
Hi Dvorak, No mesh here, just a wireless AP and the Hub. If I pull the wire connecting the TV to the router, and connect wirelessly via the AP, the issue does not occur.
3 weeks ago
@thetarpey wrote:
...My TV is wired directly to the router.
Can you clarify? You are not trying to use the same hub IP address for both your TV and phone? If so, that's not going to work.
3 weeks ago
