Network Time Still On GMT
- My Router
- Network Time Still On GMT
Re: Network Time Still On GMT
30-03-2020 12:22 PM
No, still the same today. It's been through all previous GMT/BST changes without any problem, but of course there may have been a new firmware version since October (is there a change log anywhere?).
30-03-2020 12:29 PM
How long have you had the Hub? I'm just wondering if it being a leap year has confused it - but I'm not a software engineer, so could be wrong.
There is no change log we can see (so far as I know) and have never seen a hub, let alone used one, so my comments could be wrong.
30-03-2020 12:39 PM - edited 30-03-2020 12:40 PM
I've had it since December 2017. I'm assuming it picks up & uses the time from a server somewhere, but other router models could be configured to use a different one.
30-03-2020 12:42 PM
So it has never met a leap year before. All PN customers pick up the time from ntp.plus.net time servers.
30-03-2020 2:30 PM
Mine still on GMT too. I've just moved to Plusnet, took delivery of my router on 20 March, connection went live on 25 March.
Did you try calling Ciustomer Service @BTB500?
30-03-2020 2:47 PM
I did try calling but it said minimum 30 minute wait, so I gave up. Online chat has been taken down, there doesn't seem to be any other way to contact them.
31-03-2020 5:28 PM
Hi everyone,
It is important to under stand in a discussion such as this, that posters are very clear about which router they are using "the one I got last year" is not overly helpful. Model number and firm wear version would be a great help.
There are a good number of "Plusnet" routers in the wild each functions quite differently...
- Thompson TG585 - I suspect there are not many of these left
- Thompson TG582N - arguably the best ADSL router Plusnet have offered, rich diagnostics and still plenty out there
- Hub Zero (2704n) - the first Ex-BT router - anything useful is darned near impossible to access
- Hub One (BT HH5a) - it is what it is!
There is also a variety of other routers issued for different purposes over the years and a different set of products used by the Plusnet vISP brands. I am testing one of those and have observed that though it changed from GMT to BTS … it was 5 minutes fast.
Screen shots of settings would also be helpful.
It is some while since I looked at the settings on the Hub Zero & One, but I has a vague recollection that there is a switch for "adjust for DST" on the settings of one of these routers. That needs to be set on.
Time zone should be set to London / Dublin so that GMT / DST adjustments occur on the right dates - if set to GMT then I guess that there is a fair chance that the router will not adjust the time at all / on the right dates.
It is worth checking through all of the settings then pressing SAVE to force and update - I found that caused my router to correct its 5 minute error. That problem has been escalated to Plusnet support.
If after reviewing the above the routers do not adjust for BST, please post router model numbers, firmware version and a screen shot of the time settings. I will then see if I can get someone from product support to take a look.
31-03-2020 5:36 PM
Thanks, @Townman .😁
31-03-2020 5:42 PM - edited 31-03-2020 5:43 PM
@Townman
Hi, as previously posted I'm using a Hub One. As far as I know the firmware updates automatically so I have no choice there? But anyway it shows:
"Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 22/03/19"
I couldn't find any time-related settings using the standard user interface, other than the current time being displayed in the Plusnet Access Control section (screenshot attached).
31-03-2020 5:51 PM
@Townman
I've attached screenshots of the (very limited) options available under Settings and Advanced Settings.
Thanks for your help!
31-03-2020 6:18 PM
Hi, Thank you for the screen shots - they help to some extent (they tell us where the time settings are not to be found!). I expected to see them under Advanced / System … however now I think about it, I have seen more business H1s than residential H1s and I believe they might be different.
I have asked for help from the other SUs on this one … if it were not for lock down I could be on one in 10 minutes.
Is there any hint of NTP settings under the A-Z link?
31-03-2020 6:22 PM
Hi, no the 'Help' and 'A-Z' are pretty basic. Here's the latter in full:
A
Access Control
Add new game / application
Add new game / application - IPv6
Admin password, Change
ADSL settings
B
Backup hub settings
Brightness
Broadband settings
Plusnet Broadband, Set username and password
C
Change admin password
Change wireless channel - 2.4 GHz wireless
Change wireless channel - 5 GHz wireless
Change wireless key - 2.4 GHz wireless
Change wireless key - 5 GHz wireless
Change wireless security - 2.4 GHz wireless
Change wireless security - 5 GHz wireless
Connectivity check
D
Desktop Help
Devices, Show connected
DHCP Settings
DHCP Settings - IPv6
DHCP Table
DMZ
Dynamic DNS
E
Edit a game / application
Event Log
F
Firewall
Forgotten admin password
G
H
Home network
Hub lights, change brightness
I
Internet settings
IP Address, Change
IP address of Home Hub
IPv6 address of Home Hub
IPv6 Configuration
IPv6 Gaming
IPv6 Pinholes
J
K
L
M
N
O
P
Password - Forgotten Hub Manager Password
Port forwarding
Preventing a device connecting to the Internet
Q
R
Reset Hub to factory defaults settings
Reset wireless settings to default
Restart / Reboot Hub
Restore hub settings (back-up configuration)
S
SSID / Wireless Network Name, Change - 2.4 GHz wireless
SSID / Wireless Network Name, Change - 5 GHz wireless
Supported games and application
T
U
V
Virtual Server
VPN compatibility
W
WEP, WPA, Select wireless security - 2.4 GHz
WEP, WPA, Select wireless security - 5 GHz
Wireless channel, Change - 2.4 GHz
Wireless channel, Change - 5 GHz
Wireless connections, Enable or Disable - 2.4 GHz
Wireless connections, Enable or Disable - 5 GHz
Wireless key, change - 2.4 GHz
Wireless key, change - 5 GHz
Wireless security - 2.4 GHz
Wireless security - 5 GHz
Wireless settings, reset to defaults
WPS (Wireless Push Button connection), enable or disable
X
Y
Z
31-03-2020 6:29 PM
Again, thank you for that.
Clutching at straws … I would check out Broadband and Internet settings. After that it is a push to elsewhere... for I am concluding that there might be no user configurable option here … and I am now vaguely recalling that there are a number of variations of this router residential / business and ADSL / VDSL+ADSL!
31-03-2020 6:40 PM
I went through all the settings screens originally but couldn't see anything useful - it's all pretty basic. Screenshots attached.
Worth mentioning that the last firmware change on the box was before the March 2019 GMT->BST change, which worked fine (as did the BST->GMT change in October). Which is why I was guessing it was something external like a server that hadn't had the time updated.
31-03-2020 7:43 PM
Hi @Townman,
Please find attached screenshots of my router details, and my Access Control screen details.
I confirm that the Access Control screen, which shows the "Current time" as 18:29 was taken at 19:29 BST.
I cannot find neither an "Adjust for DST" nor a Time Zone setting.
I would be most grateful if you could get Product Support to take an interest.
Regards.
