Network Adapter Drops connection to router
FIXED- Subscribe to RSS Feed
- My Router
- Network Adapter Drops connection to router
23-06-2021 7:25 PM - edited 23-06-2021 7:33 PM
Using Window 7 when I take a break and the computer goes into sleep mode it often loses the connection to the router.
This happens with both Hub One and a BT Hub 6. All settings look as they should be and a full reboot restores the connection.
Has anyone else had this problem?
Fixed! Go to the fix.
23-06-2021 8:29 PM
@TeeGee I'm no expert in this field, but is the adapter set to 'power-saving' mode?
Re: Network Adapter Drops connection to router
25-06-2021 12:35 PM
Interesting sufggestion @jab1 If I can find its properties I will take a look.
It never gave any problems with ADSL/Netgear but I must not be too quick to blame FTTC and BT/PN !
25-06-2021 6:46 PM
Update @jab1 - I have found properties and disable Energy Efficient Ethernet. Will report back on this although may be some time. I am reaching the point wher Saving The Planet is more trouble than it is worth!
28-06-2021 11:28 AM
- My Router
