Network Adapter Drops connection to router
TeeGee
Seasoned Pro
Using Window 7 when I take a break and the computer goes into sleep mode it often loses the connection to the router.
This happens with both Hub One and a BT Hub 6. All settings look as they should be and a full reboot restores the connection.
Has anyone else had this problem?
4 REPLIES 4
Fixes: 91
Re: Network Adapter Drops connection to router
@TeeGee I'm no expert in this field, but is the adapter set to 'power-saving' mode?
TeeGee
Seasoned Pro
Interesting sufggestion @jab1  If I can find its properties I will take a look.
It never gave any problems with ADSL/Netgear  but I must not be too quick to blame FTTC and BT/PN !
TeeGee
Seasoned Pro
Update @jab1  -  I have found properties and disable Energy Efficient Ethernet. Will report back on this although may be some time. I am reaching the point wher Saving The Planet is more trouble than it is worth!
TeeGee
Seasoned Pro
@jab1
Stayed connected all night in "sleep" mode so worth a Fix for you!
TVM  TG
