Netgear ORBI RBK50 in Router Mode
FIXED- Subscribe to RSS Feed
- My Router
- Netgear ORBI RBK50 in Router Mode
24-08-2021 7:16 AM - edited 24-08-2021 7:17 AM
Using a BT Smart Hub (HH6) with a PlusNet FTTC connection. I was trying to improve my WiFi performance in parts of the house furthest from the router so I invested in the two-node RBK50 WiFi mesh kit. Set it up last night, disabled WiFi on my router and moved all ethernet-connected devices from the router to the main RBK50.
I also have Sky Q with one Mini box, but I have disabled their WiFi mesh and connected both boxes to the RBK50'S via ethernet.
So far everything seems to be working well, however I was expecting the RBK50 to install in AP mode and it seems to have chosen Router mode instead. Devices connected to the RBK50's are being assigned IP's in the 10.0.0.2, etc range. Does this mean there is a double NAT situation happening? I've been warned this is a bad thing. Should I be concerned?
Appreciate everyone's advice here!
Many thanks!
Fixed! Go to the fix.
24-08-2021 8:25 AM - edited 24-08-2021 8:32 AM
@joncollin81 Welcome to the forum.
Yes, yiu are double NATing, see https://kb.netgear.com/30186/What-is-Double-NAT. You are using scenario 2.
Your cheapest solution is to go on to an auction site, flog your Smarthub and buy a Huawei HG612 Model 3B Modem.
Alternatively buy a new VDSL modem or a combined modem/router with the capability to be run in bridge mode. I believe that cheap TP-Link ones can.
If you use the mesh in AP mode you lose the use of any extra bells and whistles such as guest mode (should it have one).
I have never tried it but think that the Business versions of the Smarthub can be set up in Bridge Modem mode.
Re: Netgear ORBI RBK50 in Router Mode
24-08-2021 10:12 AM
- My Router
