Netgear N150 DGN1000 DOES NOT WORK with Fibre
FIXED- Subscribe to RSS Feed
- My Router
- Netgear N150 DGN1000 DOES NOT WORK with Fibre
20-02-2017 4:35 AM - edited 20-02-2017 10:59 AM
I've just signed up to Plusnet Fibre and the hub it came with is, unless I've missed the advanced settings page I was looking for, lacklustre to say the least.
Some of my games require static routes and I used to be able to find which DNS was fastest and change to that etc. Can't do any of that on the plusnet thing.
Previously was on ye olde tinterwebs using a Netgear N150 DGN1000 router.
Does anyone know if there's any way to use the netgear instead of the plusnet hub thing or piggyback the netgear off it?
Failing that, anyone know a not too expensive router I could buy to replace?
Thanks in advance
Fixed! Go to the fix.
Re: Netgear N150 DGN1000
20-02-2017 9:13 AM
MIGHT have sorted it.
Connected mi netgear to the rubbish plusnet hub (wire from Lan1 on plusnet to Lan1 on netgear) and seemed to work ok but DNS wasn't right so went through all my devices individually changing the DNS to one that's better than default (Used Namebench - google it - it finds the best DNS)
Hoping someone has got a tidier solution cos that was a LOAD of faffing about LOL
20-02-2017 9:29 AM
@LeeJP77 - Can't you use this device on its own? It appears to have a a built in modem for ADSL2+. If you're on fibre then there are many options to choose from, with the major concern being how much you're willing to pay for one. If it were me then I'd be inclined to buy a DrayTek, but others will have different opinions.
20-02-2017 9:46 AM - edited 20-02-2017 9:53 AM
I tried using it on it's own but I don't know the settings for fibre. I know you have to set it for PPPoE and put your username and password in, after that, I'm a bit lost LOL
When I tried using it instead of the plusnet thingy it couldn't find the internet.
20-02-2017 10:04 AM
As you're using fibre then this Netgear won't work, as it's only a ADSL2+ modem not a VDSL (fibre). So you can either use the Plusnet provided one, stick with your current solution or invest in a VDSL compatible modem / router. I think you'll find the ball lying in your court now.
20-02-2017 10:06 AM - edited 20-02-2017 10:09 AM
My current solution isn't working as well as I thought it was so need to buy an as cheap as possible (I'm poor LOL) modem / router for fibre that lets you change the DNS and set static routes
20-02-2017 10:12 AM
Well, that's easy. Set your budget and see what's on offer for the price, then make your choice based on your needs and maybe any (credible) reviews you can find. By credible I mean, PC magazines, Toms Hardware, etc. not TrustPilot, etc or any of its ilk.
20-02-2017 10:16 AM
I don't know what I'm looking for though. I tried searching ebay for fibreoptic routers and it came up with nothing. Just looked for daytrek and a load came up but don't know which, if any, work with fibreoptic LOL
20-02-2017 10:19 AM
Have a look over on Kitz
20-02-2017 10:22 AM - edited 20-02-2017 10:26 AM
Thanks mate, just having a look at the list. MOST are wildly out of my price-range, could stretch to the £40 ones if I decide to live on toast for a month (did it for 2yrs, a month should be fine LOL) ... Shall look closer at that list and look for the cheaper ones on ebay and see if I get a result LOL 🙂
They all work with Fibre, yes? And do basic stuff like changing DNS and setting Static routes?
20-02-2017 10:35 AM - edited 20-02-2017 10:40 AM
@Mustrum @Anonymous Just bought this. It's on the list. £30.
http://www.ebay.co.uk/itm/Open-Box-TP-Link-TD-W9970-300Mbps-Wireless-N-USB-VDSL2-Modem-Router-/272543517664?hash=item3f74dc0be0:g:8QQAAOSwjDZYa6vo
20-02-2017 10:45 AM
Looks like a sensible buy, and it only means three weeks of toast.
20-02-2017 10:56 AM
Yeah, already started rationing the extravagant things like coffee etc LOL
20-02-2017 11:15 AM - edited 20-02-2017 11:16 AM
Quite a few people with that router, its seems to work OK, and a bargain at that price.
20-02-2017 11:32 AM
As long as it does the job (which the piece of turd plusnet thingy I got sent doesn't) ... I'm happy 😄
- My Router
