Netgear DM200 modem and a Netgear R8000 router does not connect....
- My Router
- Re: Netgear DM200 modem and a Netgear R8000 router...
19-06-2020 7:14 AM
Been at this a while.... like a week.
I got a new Netgear DM200 and i set it to modem only mode and iget three green lights on front after 5 min's.
I then connect the Netgear R8000 router to it and insert my plusnet user and password into the router but it does not connect to plusnet.
I have tried every way to connect this up but still no joy.. what am I missing.
Thanks.
Re: Netgear DM200 modem and a Netgear R8000 router does not connect....
19-06-2020 7:34 AM
Is it a Fibre(fttc) connection ?
If so, you vlan ID set to 101.. Normally this would be set on the modem but there seems to be some confusion with the Dm200 & router scenario as to where and how it's set.
Hopefully someone with hands on experience will be along to advise further
19-06-2020 7:47 AM
They say to set Netgear DM200 to modem only add insert username and password into the Netgear router and it will connect...
Always-on Broadband xDSL
All cables have been checked and user name / password are correct. Plusnet acount working..
The Netgear DM200 modem works Netgear R8000 with a friends account (BT)
So what is not working with me....
Regards.
19-06-2020 7:54 AM
Have you added the @plusdsl.net to the end of your username ?
19-06-2020 7:21 PM
Sorry for late reply,
Yes I use my complete user name and correct password into router.
The DM200... I believe you do not use any user name or password in that as you are using it as a modem and that makes the connection to Plusnet and it's the router that you put user name and password into.
They make it sound so simple in the setup instructions to setup.
Thanks.
20-06-2020 6:35 PM - edited 20-06-2020 6:45 PM
deleted
- My Router
