Netgear D6400 VDSL // REFUSES to connect to Plusnet service // HELP!
- My Router
- Netgear D6400 VDSL // REFUSES to connect to Plusne...
23-08-2017 9:45 AM - edited 23-08-2017 10:30 AM
Re: Netgear D6400 VDSL // REFUSES to connect to Plusnet service // HELP!
23-08-2017 10:04 AM
23-08-2017 10:06 AM
Broadband Fault Reporting :
Contact/Chat : CHAT service only operational in certain daytime hours.
BT Wholesale Speed Test:
23-08-2017 10:31 AM
Yeah sorry VLAN ID is 101 and 'username@plusdsl.net' isn't my real username I have edited the original post to include this information.
Thanks!
Kirk
23-08-2017 1:00 PM - edited 23-08-2017 1:04 PM
First thought is that the full factory reset has not taken properly.
I would have expected it to change the WiFi password to some default value or blank it - and I don't think fluffychair460 is a likely default! I would check the instructions for doing a full factory reset or what they call a 30/30/30 reset and try to do it again - possibly a couple of times.
23-08-2017 1:42 PM
Good point about the 30/30/30 reset. If I can get that to work then who knows. I might even be able to use the latest firmware. It can't be a good sign if you're having to use outdated firmware to get the thing to work properly.
Is there anyone out there that has a D6400 and if so were you able to connect to Plusnet (VDSL) with the Netgear genie?
Thanks!
23-08-2017 2:30 PM
Perhaps if you posted your Netgear "Internet Set Up" page, from admin settings, obliterating
anything confidential, someone could assist.
23-08-2017 8:28 PM
Hey all,
I'm CONNECTED!
Well as it turns out it was indeed my password that was the problem. The Netgear must have somehow not been able to transmit it during authentication. Specifically it was a ; (semi colon) in my password that was the problem. I used the same password without the ; then connected using the Network genie. Straight in no bother at all!
Now I'm fully up and running albeit with slightly older firmware. I don't mind as all appears to be well so as it is not broken then I shall not fix it!
***IF YOU HAVE A NETGEAR D6400 DO NOT USE A ";" IN YOUR PASSWORD***
This would have saved me about 3 hours messing around trying to get it to connect. The fact it behaved a bit strangely when not fully resetting properly and unable to use newer firmware led me up the garden path, but it's fixed now and I'm happy with that!
Thanks all. Lesson learned
- My Router
