Netgear D6220 Router settings - Plusnet one dropping out
Tidyup
So I know my connection is good, all tested and I know the PlusNet router works all tested, so I have a connection of sorts. However the Plusnet standard router is dropping out infrequently and the speeds vary from 0 to 25, well below the 36 I'd expect. So, I have the Netgear D6220 which I used before, it's fibre ready and Plusnet suggested I try this out instead.
Trouble is I can't seem to get it working.
You can see my settings here, I've also tried this on PPoA and no joy.
Anyone got ideas on what might not be right?
I have typed the password in a few times, it just doesn't seem to want to connect.
16 REPLIES 16
Mustrum
Fixes: 76
Re: Netgear D6220 Router settings - Plusnet one dropping out
If this is for VDSL/fibre, you forgot to tick the VLANID box.
PS you should also tick the get ip from the isp, even if you have a static ip.
Fixes: 1,482
Moderators Note
This topic has been moved from Fibre to My Router
Mustrum
Fixes: 76
i have a D7000, so some settings may b different, but these may help.:
Transfer Mode
DSL Mode
Enable This Interface
Use VLANID
        Priority (0 ~ 7)
Does your Internet connection require a login?
Yes
No
Encapsulation
Service Name
Champnet
Aspiring Hero
Fixes: 11
I’ll check my D6400 setting when I get the chance, one obvious fault: IP address should be get dynamic address from ISP.
Champnet
Aspiring Hero
Fixes: 11
Transfer mode : PTM
DSL mode : VDSL2
Tick use VLANID (101 &0)
everything else looks good......
Tidyup
Thanks all, really quick replies, so thanks.
I can't test properly this evening as family on internet, but will try tomorrow. I have been able to change some settings without plugging cable in, just by switchign to the wifi even though its not connected.
I have switched to VLANID.
Transfer and DSL mode won't allow me to swap, keeps reverting back to ATM and Auto when I do this. Maybe it will when the cable is connected.
Wil try tomorrow when I can kick the family off and let you know how its gone.
Champnet
Aspiring Hero
Fixes: 11
For info d6400
Tidyup
Champnet, out of interest, why do you have PPPoE over PPPoA, I always thought A was slightly better/faster?
Champnet
Aspiring Hero
Fixes: 11
Both should work but I’ve always considered PPPoE to be more stable than PPPoA.
The experts may be along shortly to argue one is better than the other.....
have you got your connection working ?
Tidyup
Annoyingly I can't get to it until son and wife in bed!
If I downtime Netflix, Amazon or Fortnite I will be hassled all round the house ;o)
Quieter at night, so will try then. I fel more confident in the settings you all shared, so fingers crossed and I'll be back to report either way 🐵
RealAleMadrid
Aspiring Hero
Fixes: 59
@Tidyup VDSL2 login type is always PPPoE, you don't have a choice. PPPoA can be used on ADSL, it means Point-to-Point Protocol over ATM. VDSL uses a different transfer mode which is PTM, it all gets a bit technical to explain any further.🤔
Tidyup
Hey all,
Many thanks for the help, looks like it's running, coulnd't have done it without you. Plusnet support seems to stop if not their router.
To help any others who might be look: -
D6220 Netgear Router and Plusnet Broadband settings are in image below.
Tidyup
I have one further question. The speeds seems over 25-30Mbps now, so much better. Download is 1-2 though and was 7-8 on Plusnet router, anything that can be tweaked that people know of on Netgear upload?
Tidyup
The graph shows this now, upload higher was with Plusnet router, lower with NetGear.
But download much better with Netgear, 25-35, was 1-20 on Plusnet.
