NTP synchronization failure!
- My Router
- NTP synchronization failure!
17-05-2020 10:29 PM
I have noted in the event log that the dates are not correct. Looking further i have noted that the NTP is not syncing.
02:26:16, 10 Nov. | (181576.620000) NTP synchronization failure! |
02:17:05, 10 Nov. | (181026.580000) NTP synchronization failure! |
02:07:55, 10 Nov. | (180476.520000) NTP synchronization failure! |
01:58:45, 10 Nov. | (179926.480000) NTP synchronization failure! |
01:49:35, 10 Nov. | (179376.450000) NTP synchronization failure! |
01:40:25, 10 Nov. | (178826.410000) NTP synchronization failure! |
01:31:15, 10 Nov. | (178276.370000) NTP synchronization failure! |
01:22:05, 10 Nov. | (177726.340000) NTP synchronization failure! |
01:12:55, 10 Nov. | (177176.300000) NTP synchronization failure! |
01:03:45, 10 Nov. | (176626.250000) NTP synchronization failure! |
00:54:35, 10 Nov. | (176076.220000) NTP synchronization failure! |
00:45:25, 10 Nov. | (175526.170000) NTP synchronization failure! |
00:36:15, 10 Nov. | (174976.130000) NTP synchronization failure! |
00:27:05, 10 Nov. | (174426.100000) NTP synchronization failure! |
00:17:55, 10 Nov. | (173876.030000) NTP synchronization failure! |
00:08:45, 10 Nov. | (173326.000000) NTP synchronization failure! |
23:59:35, 09 Nov. | (172775.970000) NTP synchronization failure! |
23:50:25, 09 Nov. | (172225.930000) NTP synchronization failure! |
23:41:15, 09 Nov. | (171675.750000) NTP synchronization failure! |
23:32:05, 09 Nov. | (171125.660000) NTP synchronization failure! |
23:22:55, 09 Nov. | (170575.610000) NTP synchronization failure! |
23:13:44, 09 Nov. | (170025.410000) NTP synchronization failure! |
23:04:34, 09 Nov. | (169475.250000) NTP synchronization failure! |
22:55:24, 09 Nov. | (168925.000000) NTP synchronization failure! |
22:46:14, 09 Nov. | (168374.940000) NTP synchronization failure! |
22:37:04, 09 Nov. | (167824.900000) NTP synchronization failure! |
22:27:54, 09 Nov. | (167274.810000) NTP synchronization failure! |
22:18:43, 09 Nov. | (166724.230000) NTP synchronization failure! |
22:09:33, 09 Nov. | (166173.940000) NTP synchronization failure! |
22:00:23, 09 Nov. | (165623.730000) NTP synchronization failure! |
21:51:13, 09 Nov. | (165073.590000) NTP synchronization failure! |
21:42:02, 09 Nov. | (164523.440000) NTP synchronization failure! |
21:32:52, 09 Nov. | (163973.340000) NTP synchronization failure! |
21:23:42, 09 Nov. | (163423.240000) NTP synchronization failure! |
21:14:32, 09 Nov. | (162873.130000) NTP synchronization failure! |
21:05:22, 09 Nov. | (162322.830000) NTP synchronization failure! |
20:56:12, 09 Nov. | (161772.620000) NTP synchronization failure! |
20:47:01, 09 Nov. | (161222.450000) NTP synchronization failure! |
20:37:51, 09 Nov. | (160672.250000) NTP synchronization failure! |
20:28:41, 09 Nov. | (160122.060000) NTP synchronization failure! |
20:19:31, 09 Nov. | (159571.770000) NTP synchronization failure! |
20:10:20, 09 Nov. | (159021.300000) NTP synchronization failure! |
20:01:05, 09 Nov. | (158466.230000) NTP synchronization failure! |
19:51:55, 09 Nov. | (157916.150000) NTP synchronization failure! |
19:42:45, 09 Nov. | (157366.120000) NTP synchronization failure! |
19:33:35, 09 Nov. | (156816.090000) NTP synchronization failure! |
19:24:25, 09 Nov. | (156266.050000) NTP synchronization failure! |
19:15:15, 09 Nov. | (155716.010000) NTP synchronization failure! |
19:06:05, 09 Nov. | (155165.950000) NTP synchronization failure! |
18:56:55, 09 Nov. | (154615.890000) NTP synchronization failure! |
18:47:44, 09 Nov. | (154065.420000) NTP synchronization failure! |
18:38:34, 09 Nov. | (153515.360000) NTP synchronization failure! |
18:29:24, 09 Nov. | (152965.330000) NTP synchronization failure! |
18:20:14, 09 Nov. | (152415.300000) NTP synchronization failure! |
18:11:04, 09 Nov. | (151865.270000) NTP synchronization failure! |
18:01:54, 09 Nov. | (151315.240000) NTP synchronization failure! |
17:52:44, 09 Nov. | (150765.190000) NTP synchronization failure! |
17:43:34, 09 Nov. | (150215.160000) NTP synchronization failure! |
17:34:24, 09 Nov. | (149665.130000) NTP synchronization failure! |
17:25:14, 09 Nov. | (149115.100000) NTP synchronization failure! |
17:16:04, 09 Nov. | (148565.000000) NTP synchronization failure! |
17:06:54, 09 Nov. | (148014.870000) NTP synchronization failure! |
16:57:44, 09 Nov. | (147464.840000) NTP synchronization failure! |
16:48:34, 09 Nov. | (146914.720000) NTP synchronization failure! |
16:39:24, 09 Nov. | (146364.690000) NTP synchronization failure! |
16:30:14, 09 Nov. | (145814.660000) NTP synchronization failure! |
16:21:04, 09 Nov. | (145264.630000) NTP synchronization failure! |
16:11:54, 09 Nov. | (144714.600000) NTP synchronization failure! |
16:02:43, 09 Nov. | (144164.560000) NTP synchronization failure! |
15:53:33, 09 Nov. | (143614.530000) NTP synchronization failure! |
15:44:23, 09 Nov. | (143064.490000) NTP synchronization failure! |
15:35:13, 09 Nov. | (142514.460000) NTP synchronization failure! |
15:26:03, 09 Nov. | (141964.420000) NTP synchronization failure! |
15:16:53, 09 Nov. | (141414.380000) NTP synchronization failure! |
15:07:43, 09 Nov. | (140864.340000) NTP synchronization failure! |
14:58:33, 09 Nov. | (140314.300000) NTP synchronization failure! |
14:49:23, 09 Nov. | (139764.270000) NTP synchronization failure! |
14:40:13, 09 Nov. | (139214.240000) NTP synchronization failure! |
14:31:03, 09 Nov. | (138664.210000) NTP synchronization failure! |
14:21:53, 09 Nov. | (138114.180000) NTP synchronization failure! |
14:12:43, 09 Nov. | (137564.150000) NTP synchronization failure! |
14:03:33, 09 Nov. | (137014.110000) NTP synchronization failure! |
13:54:23, 09 Nov. | (136464.070000) NTP synchronization failure! |
13:45:13, 09 Nov. | (135914.030000) NTP synchronization failure! |
13:36:03, 09 Nov. | (135364.000000) NTP synchronization failure! |
13:26:53, 09 Nov. | (134813.970000) NTP synchronization failure! |
13:17:43, 09 Nov. | (134263.940000) NTP synchronization failure! |
13:08:33, 09 Nov. | (133713.910000) NTP synchronization failure! |
12:59:23, 09 Nov. | (133163.870000) NTP synchronization failure! |
12:50:13, 09 Nov. | (132613.840000) NTP synchronization failure! |
12:41:03, 09 Nov. | (132063.800000) NTP synchronization failure! |
12:31:53, 09 Nov. | (131513.750000) NTP synchronization failure! |
12:22:43, 09 Nov. | (130963.720000) NTP synchronization failure! |
12:13:33, 09 Nov. | (130413.690000) NTP synchronization failure! |
12:04:23, 09 Nov. | (129863.650000) NTP synchronization failure! |
11:55:13, 09 Nov. | (129313.620000) NTP synchronization failure! |
11:46:03, 09 Nov. | (128763.590000) NTP synchronization failure! |
11:36:52, 09 Nov. | (128213.560000) NTP synchronization failure! |
11:27:42, 09 Nov. | (127663.530000) NTP synchronization failure! |
11:18:32, 09 Nov. | (127113.500000) NTP synchronization failure! |
1. Product name: | Plusnet Hub |
2. Serial number: | +081441+NQ65002845 |
3. Firmware version: | Software version 4.7.5.1.83.8.263 Last updated 30/03/19 |
4. Board version: | Plusnet Hub One |
5. DSL uptime: | 2 days, 02:33:26 |
6. Data rate: | 16562 / 73909 |
7. Maximum data rate: | 16536 / 89564 |
8. Noise margin: | 6.0 / 10.3 |
9. Line attenuation: | 10.5 / 7.9 |
10. Signal attenuation: | 11.3 / 7.9 |
11. Data sent/received: | 3.0 GB / 42.7 GB |
12. Broadband username: | *removed for security*@plusdsl.net |
13. 2.4 GHz Wireless network/SSID: | *removed for security* |
14. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 300 Mb/s)) |
15. 2.4 GHz Wireless security: | WPA2 |
16. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
17. 5 GHz Wireless network/SSID: | *removed for security* |
18. 5 GHz Wireless connections: | Enabled (802.11 a/n/ac (up to 1300 Mb/s)) |
19. 5 GHz Wireless security: | WPA2 |
20. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
21. Firewall: | Default |
22. MAC Address: | *removed for security* |
23. Modulation: | G.993.2 Annex B |
24. Software variant: | AA |
25. Boot loader: | 1.0.0 |
Labels:
Message 1 of 1
(249 Views)
- My Router
