NAS drive connection from chromebook?
FIXED- Subscribe to RSS Feed
- My Router
- NAS drive connection from chromebook?
20-01-2019 12:11 PM
Hi. I'm using a chromebook and trying to connect to nas drive, samsung m3 1tb. I think I'm using the correct address and syntax, smb:\\Pnhub1\usb1 tried both with and without user and pwd. However I get an error message saying Samba v2 is needed. Where is that held, in chromebook, router or nasdrive? Any thoughts welcome. I might try a usb stick to see if that makes any difference.
Fixed! Go to the fix.
20-01-2019 12:59 PM - edited 20-01-2019 12:59 PM
MIcrosoft deprecated SMB (Samba) V1 some while ago. I'm not sure about this but I suspect that the Chromebook is using SMB V2 and will not allow connection to an SMB V1 share. This thread https://community.plus.net/t5/My-Router/Plusnet-hub-one-usb-port/td-p/1343417 seem to imply that the Hub one will only support SMB V1
Re: NAS drive connection from chromebook?
21-01-2019 9:40 AM
Thanks Mrw. I suspected it would be that, the error message says so, so I'll have to wait till the hub is upgraded, if ever.
23-01-2019 9:52 PM
I would buy a NAS drive (rather than use the USB drive with the Plusnet router).
Depending on requirements and budget, I've used both the WD MyCloud or the lower end of the Synology range successfully.
Of the two, I now think the Synology would be my recommendation and it's ability to make a simple USB printer work with iOS AirPrint is very neat.
24-01-2019 9:33 AM
I have both already. It's been stated on another thread that a chromebook needs samba v2, pnhub has v1 with no plans to upgrade, so it just won't work from the chromebook. grrr!
- My Router
