My wifi is broadcasting two different network names at the same time
apostle
My internet speed got slow recently. I did some troubleshooting, the usual stuff: checked the cables, tinkered with the settings, etc. I also used Wifi Analyser to look up the least crowded channel, but then I saw that there's another strong SSID on the same channel:
https://i.imgur.com/Jycd0qk.jpg
Not knowing what it is, I switched to another channel, and the DIRECT-SYSDESKTOP-CP******* followed in the new channel. Obviously it must have originated from my modem.
Since my internet speed is still crawling, I decided to reset the modem. And after that, I saw this:
https://i.imgur.com/Yy3WBPd.jpg
I guess there's no running away from it. But at least my speed is back up to normal now.
So my question is: why is my modem broadcasting another SSID? And is it anything to be worried about?
Tags (3)
7 REPLIES 7
Alex
Fixes: 13
Re: My wifi is broadcasting two different network names at the same time
It could possibly be for different channels, my router does this for 2.4Ghz and 5Ghz.
EDIT: I meant frequencies.
apostle
I really doubt it. I can't connect to it using any known password. And the mystery SSID doesn't match the default SSID even after reset.
Browni
Aspiring Hero
Fixes: 61
Could it be your PC  is acting as a WiFi hotspot?
This link shows how to enable/disable.
corringham
Seasoned Champion
Fixes: 23
It seems a little strange to me that the SSIDs have different signal strengths if they are originating from the same device. I run multiple SSIDs and they all have the same signal strength.
Do you by any chance have a smart TV or a wi-fi accessible printer that allows you to connect directly without using a network?
Fixes: 480
You don't say what router you have. It's not one that provides a guest network is it?
apostle
You might be on to something here. I checked the PC settings and the SSID is exactly the same as the 'mystery' one! But I've never ever used my PC as a mobile hotspot before. Just to be safe, I disabled the adapter alogether.
And now the 'mystery' SSID is gone! Thank you so much! CheesyCheesyCheesy
Browni
Aspiring Hero
Fixes: 61
Glad to be of help Smiley
