My smart TV connecting to wifi
tosko
My smart TV was connected to my wifi without any problems.Switched my TV on today put on netflix but said I was not connected tryed everything to connect but came up error 170.Has anyone came across this and how do you fix it?
3 REPLIES 3
Fixes: 479
Re: My smart TV connecting to wifi
Moderators Note
This topic has been moved from  Broadband to My Router
RPMozley
Seasoned Pro
Fixes: 16
Do the other connected services work and only Netflix has the problem?
That's RPM to you!!
TheMightyAJ
Fixes: 126
Hey @tosko,
I'm sorry to hear that you've run into this issue. As @RPMozley's asked, are you noticing the issue with any other services or does it only seem to be Netflix that's having problems? Also, have you had a chance to connect the TV to the router via Ethernet cable to see if this makes any difference?
 Alex H
