My router needs replacing
- My Router
- My router needs replacing
06-06-2020 7:57 PM
I have had my PlusNet router for about 3 years and the wifi range has dropped, so can only access in one room. Used to be able to get it throughout the house. Have reset the router and changed the ADSL filter, but nothing works.
It's just old and needs replacing. How do I get a replacement router
Thanks,
Tony
Re: My router needs replacing
07-06-2020 7:50 AM
@Tony1964 When is your contract due for renewal? If it is fairly soon, you could always ask for a new router as part of the package, otherwise a new PN router would cost you IIRC £60. You would be better off having a look on eBay for a BT HH6 at around £20-£25 - a much better option.
