My router is not working
dmarks70
My routers light has changed to orange and I have no WiFi. It just changed suddenly. I have tried switching it on and off. Do I need an engineer to have a look and fix it? Thanks
4 REPLIES 4
bobpullen
Fixes: 314
Re: My router is not working
What router are you using, and it the light solid orange, or flashing? Have you tried powering the router off/back on and if so, does that make any difference?
dmarks70
Hi, I’ve got the router plusnet supplied. It’s solid orange and there seems to be a little ‘b’ under it that randomly flashes on and off. Thanks
dmarks70
I have tried switching it on and off. Thanks!
bobpullen
Fixes: 314
The flashing 'b' suggests you may have a line fault.
First thing I would suggest is to raise a fault ticket here.
