My router is not working
- My Router
- Re: My router is not working
29-07-2021 11:06 PM
29-07-2021 11:39 PM
What router are you using, and it the light solid orange, or flashing? Have you tried powering the router off/back on and if so, does that make any difference?
29-07-2021 11:47 PM
29-07-2021 11:48 PM
30-07-2021 12:00 AM
The flashing 'b' suggests you may have a line fault.
First thing I would suggest is to raise a fault ticket here.
- My Router
