My router is buzzing
Grhmeh
Just noticed that my plusnet hub one router has a low level on off buzzing sound , the unit is a year old any ideas what it is ,is it about to fail.
6 REPLIES 6
Fixes: 419
Re: My router is buzzing
It is probably an isolation transformer. These routers can make this noise if fitted with a poorly manufactured device. It's not dangerous, just annoying. If it's out of guarantee your choices are either to negotiate a new contract in exchange for a new router or buy your own. My recommendation is to go to Ebay and spend about £30 on a BT. Smarthub 6. You will find settings for use with Plusnet on this board and you will benefit from better wifi performance.
bobpullen
Fixes: 316
Happy to send a replacement if you don't mind shipping the one you have back to our offices marked for my attention? I'd be happy to apply some credit to your account to cover the postage. That OK?
Grhmeh
Yes I will accept your offer of a new router and send the old unit back to you. Will the replacement be new or refurbished.
bobpullen
Fixes: 316
It will be new. I'm actually on leave until Wednesday but I'll try and hop onto the VPN at some point this weekend and arrange.
bobpullen
Fixes: 316
I've just ordered the replacement unit. All being well your Royal Mail postie should deliver it on Tuesday. Let me know when the buzzing unit is in the post and I'll apply some credit to your account to cover the postage.
bobpullen
Fixes: 316
@Grhmeh, thanks for sending the router back, I've now received it and processed a £5 refund to your account for your troubles. It should hit your account by the end of the week all being well.
