My hub is connected but my internet will not connect
FIXED- Subscribe to RSS Feed
- My Router
- My hub is connected but my internet will not conne...
13-03-2019 7:59 AM
Hi, I just had my hub installed on 11/3 and this morning it finally went into blue light with no red for the broadband, I can connect to the hub using ethernet cable or WiFi but have no internet access, please can someone help me sort htis out
Fixed! Go to the fix.
Re: My hub is connected but my internet will not connect
13-03-2019 11:45 AM
Hi @lrevin,
I'm sorry that you've been unable to get online and for any inconvenience that this is causing you. I've checked on your order and, although this has completed on our supplier's system this hasn't automatically completed on our side which means that you're unable to get onto our network.
I've manually closed off the order now and you should be able to get online. If it still won't allow you to get online, please factory reset the router via the pinhole on the back.
13-03-2019 12:25 PM
Sadly this has not fixed the problem, when the hub was restarted it goes: Flashing Green - Solid Blue - Flashing Orange - Solid Orange & Red Broadband - Solid Blue, can still connect to the hub but not the actual internet.
13-03-2019 12:54 PM
Thank you for the assistance, my missus was on the phone to your colleagues and they have managed to sort it out.
Best Regards
13-03-2019 1:44 PM
Good to know @lrelvin
If you ever need any more assistance then please don;t hesitate to give us a shout.
Kind Regards,
MoR
- My Router
