My Plusnet router makes a hissing sound
hiker1234
Hi
My Plusnet router makes a hissing sound whenever it's receiving data — downloading web-pages or files, streaming, etc.
This seems to be a problem experienced by others.
I've tried to call, but there's no answer.
Could you send me a replacement?
5 REPLIES 5
bill888
Aspiring Champion
Fixes: 32
Re: My Plusnet router makes a hissing sound
fwiw, try phoning Plusnet as soon as their offices open. Normally 8am on weekdays.  Usually little or no queue.
hiker1234
Thanks for the tip. Smiley
Flagstaffer
mine makes hiding sound too, constantly, and it's right by my bed, really annoying. Did you get through to them. What was the solution?  Thanks
hiker1234
I gave-up trying to contact them, but turning-off the 5Ghz, in the router settings, as suggested above, worked.
Flagstaffer
Thanks - I'm going to try to switch to old BT router if that doesn't work, I'll try turning of the 5Ghz.
Many thanks.
