My P2P usage
FIXEDTopic Options
- My Router
- My P2P usage
23-07-2017 5:08 PM
Can I tell from my router, how much I am uploading and downloading and also P2P usage
Fixed! Go to the fix.
Message 1 of 2
(403 Views)
1 REPLY 1
24-07-2017 8:09 AM
Normally the router will just give you the total bytes uploaded and downloaded since it last connected. You can see your usage breakdown in the Plusnet Member Centre, login and select View Your Broadband usage and then click on usage breakdown at the bottom right.
