Moving from ADSL to fibre process
- My Router
- Re: Moving from ADSL to fibre process
11-12-2017 2:41 PM
Hub one on its way but not due to be upgraded until 28th December. Can I just hook up the Hub one to ADSL and everything will then just happen on the day (maybe a reboot at most) or doesn't it work that way or is it not advised?
I can keep the old router running on ADSL until the switchover day if thats the best way to go about it.
PT
11-12-2017 4:00 PM
11-12-2017 9:21 PM
Thanks, realised that but will it just magically move to fibre or do I need to do anything?
12-12-2017 3:27 PM - edited 12-12-2017 3:28 PM
Hi there.
Yep, the Hub One will work on ADSL too. If you set it up before your upgrade, you should just experience a relatively brief drop in your connection on the day as the work completes. When it comes back up, you should be on fibre.
Let us know how it goes.
12-12-2017 3:35 PM
Great thanks
It's arrived and boy is it one pig ugly router. Wife won't have that visible anywhere. Looks like a cheap kids toy. Shame they didn't just put the PN logo on the HH5 and leave the rest as it was as that doesn't look too bad.
I'll get things up and running and get something more aesthetically pleasing once I'm happy its all ok.
Jon
12-12-2017 3:58 PM - edited 12-12-2017 3:59 PM
12-12-2017 4:58 PM - edited 12-12-2017 5:03 PM
True,
been looking at something more traditional and inconspicuous to please my wife.
Current favourite (ARCHER VR2800) =
12-12-2017 5:01 PM
She doesn't mind this one but the spec is not so good and I've never been very happy with Netgear kit
12-12-2017 5:23 PM - edited 12-12-2017 5:44 PM
I almost bought one of them (The TP-Link, not the Netgear) but eventually opted for one of these for it's G.fast support.
This is the stats from someone using it on a BT trial
12-12-2017 10:17 PM
I think by the time G.Fast comes anywhere near me I will be dribbling over my keyboard and the speed of my connection will be the least of my worries
on 13-12-2017 12:39 AM - last edited on 13-12-2017 7:10 AM by Mav
I'm dribbling over my keyboard in anticipation of them switching this one on!
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
14-12-2017 11:26 AM - edited 14-12-2017 11:28 AM
Went for this in the end. Only 12.99 for Prime customers today. Should work. Looks powerful anyway. 8 aerials
14-12-2017 11:34 AM
- My Router
