Moving from ADSL to fibre process
PhyllisTyne
Hub one on its way but not due to be upgraded until 28th December. Can I just hook up the Hub one to ADSL and everything will then just happen on the day (maybe a reboot at most) or doesn't it work that way or is it not advised?
I can keep the old router running on ADSL until the switchover day if thats the best way to go about it.
PT
12 REPLIES 12
mikelahey
Fixes: 12
Re: Moving from ADSL to fibre process
The hub one will work fine on ADSL, so you can hook it up and use while you are waiting.
PhyllisTyne
Thanks, realised that but will it just magically move to fibre or do I need to do anything?
Fixes: 1,600
Hi there.
Yep, the Hub One will work on ADSL too. If you set it up before your upgrade, you should just experience a relatively brief drop in your connection on the day as the work completes. When it comes back up, you should be on fibre.
Let us know how it goes.
PhyllisTyne
Great thanks
It's arrived and boy is it one pig ugly router. Wife won't have that visible anywhere. Looks like a cheap kids toy. Shame they didn't just put the PN logo on the HH5 and leave the rest as it was as that doesn't look too bad.
I'll get things up and running and get something more aesthetically pleasing once I'm happy its all ok.
Jon
Browni
Aspiring Hero
Fixes: 60
If you think the Hub One is ugly, what about one of these
csm_fritzbox_3490_left_de_640x400_183a71fdeb
or one of these
10399524
Funny
PhyllisTyne
True,
been looking at something more traditional and inconspicuous to please my wife.
Current favourite (ARCHER VR2800) =
41%2BznJ4IpkL
PhyllisTyne
She doesn't mind this one but the spec is not so good and I've never been very happy with Netgear kit
71HZkSxTb6L._SL1500_
Browni
Aspiring Hero
Fixes: 60
I almost bought one of them (The TP-Link, not the Netgear) but eventually opted for one of these for it's G.fast support.
u_10157995
This is the stats from someone using it on a BT trial
Yikes!Yikes!
PhyllisTyne
I think by the time G.Fast comes anywhere near me I will be dribbling over my keyboard and the speed of my connection will be the least of my worries Grin
Browni
Aspiring Hero
Fixes: 60
I'm dribbling over my keyboard in anticipation of them switching this one on!
Image and video hosting by TinyPic Dribble over these stats
stats
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
PhyllisTyne
Went for this in the end. Only 12.99 for Prime customers today. Should work. Looks powerful anyway. 8 aerials
81RhM25JY5L._SL1500_
Browni
Aspiring Hero
Fixes: 60
Looks ideal for surfing the web Grin
