Moving away from Hub One
haynesy
Having a lot of problems with WiFI with Hub One modem/router. Wifi connections keep dropping out and then it won't let people back on the WiFi. (Everything connected by ethernet cable is working fine).
Feel I should upgrade to a replacement modem/router - has anyone got any recommendations, I assume switching is fairly straightforward?
thanks
3 REPLIES 3
Fixes: 1,482
Re: Moving away from Hub One
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 1,482
a lot of people have success with the BT Smart Hub purchased from auction sites, lots of instructions and threads around this board.
haynesy
Thanks for that - will investigate !
