Moving away from Hub One
- My Router
- Re: Moving away from Hub One
25-11-2020 10:50 AM
Having a lot of problems with WiFI with Hub One modem/router. Wifi connections keep dropping out and then it won't let people back on the WiFi. (Everything connected by ethernet cable is working fine).
Feel I should upgrade to a replacement modem/router - has anyone got any recommendations, I assume switching is fairly straightforward?
thanks
25-11-2020 11:01 AM
Moderators Note
This topic has been moved from Fibre to My Router
25-11-2020 11:02 AM
25-11-2020 11:13 AM
Thanks for that - will investigate !
- My Router
