Modem won't work on older MAC OS X
ceegee
Just joined and was disappointed that the modem won't work on my laptop running MAC OS X (10.6.8).
Works on other computers and devices an my old modems (BT,EE and SKY) worked fine with laptop.
Just keeps crashing when connected (fine otherwise).
Anyone know how I could fix this?
thanks
4 REPLIES 4
Fixes: 1,600
Re: Modem won't work on older MAC OS X
Hi there.
I suspect that's due to an incompatibility between IPv6 on Mac's running the OS Snow Leopard or earlier and the Hub Zero(Sagemcom 2704n). With your older laptop disconnected from the router can you carry out the following steps?
  • Go to System Preferences
  • Click on Network
  • Click on Advanced
  • Click on the TCP/IP tab
  • Change Configure IPv6 to Off
  • Click OK and then Apply if there's a button to save the changes
  • Connect your laptop back to router
Let us know how this goes.
ceegee
Thanks for quick reply.
Have tried what you suggested and so far so good !
I will let you know back if there is a problem, but seems to have fixed it !
Thank you !
Fixes: 1,600
Perfect! Thumbs_Up
It's not very often that this kind of issue comes up but when it does it's generally easily fixed.
Strat
Fixes: 565
Moderators Note
This topic has been moved from ADSL Broadband to My Router.
