Modem mode, BT ONT and Mikrotik
Appealing8195
I would like to replace the Hub2 with a Mikrotik router, however rather than placing the Hub2 into modem mode and then connect that to the Mikrotik I would like to bypass it and connect directly to the RJ45 on the ONT modem placed by OpenReach inside my house.
https://www.bt.com/help/broadband/whats-an-openreach-modem-ont
Is that even possible? If the hub2 uses a PPPoE auth with the plusnet credentials and the same it's done on any third party router, I don't see why I need the Hub2 in modem mode, it does modulate / demodulate anything like you would with an NTU.
Any ideas?
P
2 REPLIES 2
Fixes: 585
Re: Modem mode, BT ONT and Mikrotik
Correct, you can use any router direct to the ONT providing it's configured for PPPoE with your Plusnet credentials.
In fact the hub 2 modem mode will not work between a router and an ONT. Modem mode will only work to convert ethernet to VDSL.
Appealing8195
Awesome thanks, all setup and rocking up!
