Mobile Phone / Router Issues
- My Router
- Re: Mobile Phone / Router Issues
22-04-2020 9:50 AM
22-04-2020 9:53 AM
Assuming they're iPhones and even if not you could try splitting the 2.4 and 5GHz wifi bands:
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Click 5GHz tab.
Change 'Sync with 2.4Ghz' to No.
Change the name of the 'Wireless SSID' - I added a '_5' on the end.
Save the changes.
You can then select which one you want per device.
22-04-2020 9:53 AM
This topic has been moved from Fibre Broadband to My Router.
- My Router
