Mobile Phone / Router Issues
matt1909
We're experiencing issues with mobile phone wifi connection to our router. It connects for a limited amount of time and then reverts back to mobile data, its the same issue for all 4 mobiles in our house.
2 REPLIES 2
Fixes: 1,483
Re: Mobile Phone / Router Issues
Assuming they're iPhones and even if not you could try splitting the 2.4 and 5GHz wifi bands:
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Click 5GHz tab.
Change 'Sync with 2.4Ghz' to No.
Change the name of the 'Wireless SSID' - I added a '_5' on the end.
Save the changes.
You can then select which one you want per device.
Strat
Fixes: 565
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
