Mesh integration
Lardpie
Mesh integration
Hello
After decades with them i'm about to move over from Virgin. Currently I have a TP mesh system serving the house. Its been used for a long time and i've forgotten how I set it up.
Is there anything I need to be aware of interfacing with Plusnet. Is there any special equipment to get it to work other than the supplied router.
Thank you
Eric
2 REPLIES 2
Fixes: 392
Re: Mesh integration
@Lardpie In a word - no. You may have to reset it to factory defaults, but it should be fairly easy. If you have any issues, there are plenty on here who can advise you.
@Lardpie welcome to the forum
Couple of important questions, which service have you taken, Part Fibre (FTTC) or Full Fibre (FTTP)
Which Mesh system are you using? TP-Link ?
