Making 5 GHz have separate SSID with the Hub One?
- My Router
- Re: Force Chromecast v2 to use 5 GHz with Hub One?
14-07-2016 5:20 PM
So when scanning, you see:
- ConnectionName (2.4 GHz)
- ConnectionName (5 GHz)
Is this possible?
14-07-2016 5:21 PM
The Chromecast v2 supports 5 GHz but according to the Hub One homepage, it's currently using 2.4 GHz.
Does anyone know how I can force the Chromecast onto 5 GHz?
14-07-2016 5:44 PM
Moderator's note by Mike (Mav)
Threads merged.
Forum Moderator and Customer
Re: Making 5 GHz have separate SSID with the Hub One?
14-07-2016 6:59 PM - edited 14-07-2016 7:02 PM
Yes it is possible.
Log into the Hub One by pointing a web browser to 192.168.1.254
Go to 'Advanced Settings' -> 'Wireless'.
Click on 5 GHz wireless tab
Change the 'Sync with 2.4 GHz' to 'No'.
Assign your new wireless SSID name. eg. ConnectionName-5GHz
Click on 2.4 GHz wireless tab
Assign your new wireless SSID name. eg. ConnectionName-2.4GHz
Most of the above steps are shown from 2min 30sec in the video available at this Plusnet help page under 'How to check or change my wi-fi settings'
https://www.plus.net/help/broadband/router-user-guides/
direct video link:
https://www.youtube.com/watch?v=b8CDfkR4wZU
- My Router
